Old 19th November 2012, 09:19 PM   #21
xrk971 is offline xrk971  United States
xrk971's Avatar
It is a lot of fun. Best part is instant gratification as these projects can be built in several hours. They sound very good too.
Old 20th November 2012, 03:07 AM   #22
cochleus's Avatar
Originally Posted by xrk971 View Post
Which way does your driver point? Is this foamcore board?
The driver sits at the top of the enclosure and fires down into the horn. The material is foam-core board. The path length is 62 inches.
"My desire for knowledge is intermittent; but my desire to bathe my head in atmospheres unknown to my feet is perennial and constant". --- Thoreau
Old 20th November 2012, 09:12 AM   #23
xrk971's Avatar
OK, so the horn output is perpendicular to the output direction of the front of the driver? What driver are you using? I like how you did smooth curves, that improves efficiency but let's high frequency stuff come through. Will you use stuffing anywhere?
Old 20th November 2012, 09:32 AM   #24
xrk971's Avatar
Default Cornu spiral or Fibonacci spiral for horn?
I am thinking about the next horn project. There is a cool flat panel wall hanging horn speaker called the Cornu spiral. ( 6moons audioreviews: Cornu Compact Spiral ) This would be an easy build in foamcore, or a Fibonacci sequence Spiral where the expansion ratio goes as 1:1:2:3:5:8:13 and so on. Practically it is tough to reach 13. Is there any advantage to using the magical natural expansion ratio such as used by the nautilus seashell?
Old 20th November 2012, 02:00 PM   #25
xrk971's Avatar
A quick estimate of the Cornu spiral design shown here (seb:diy:audio: Cornu Spiral Copy Horn ), re-scaled for the Vifa TC9FD will be a 20 x 20 in square (perfect for 20x30 in foamcore board stock) will result in an effective expansion ratio of about 24:1! The pathlengths (2 separate spiral lengths) will be around 1.0 and 1.36 meters for two tuning frequencies of 85 Hz and 63 Hz. The expansion ratio is huge so the bass amplification should be significant. I am thinking of modifying the design by using curves near the mouth for aesthetics and efficiency but square corners internally to act as low-pass filters.
Old 20th November 2012, 11:02 PM   #26
cochleus's Avatar
The design was intended to be a low-loss back loaded horn with the driver reversed (concave side facing into horn throat). Stuffing was only placed near the throat area to absorb higher freq. standing waves. The test speakers I used were Tang Band W4-1320 SJ. I gave up on the design but think it may have uses if crossed low enough.
Old 23rd November 2012, 01:02 AM   #27
xrk971's Avatar
Why did you give up on the design? The bookshelf back loaded horn design I described earlier finally got tested with the Viva TC9FD drivers, they work well and have very good bass. You don't need BSC given how Much bass it produces from the front facing port. The putty damped front baffle actually works - there was almost no vibration coming through whereas the undamped panels you can feel the vibrations from the music.
Old 23rd November 2012, 01:18 AM   #28
xrk971's Avatar
I have already drawn out the full scale template for the 20 x 20 in Cornu spiral horn. I used a string to measure the lowest mode and it is 61 Hz. Need to get some more foam core board stock before starting. It's like how many different speakers can one make with a TC9FD? We know it works great in the Manzanita OB.
Old 23rd November 2012, 02:22 AM   #29
cochleus's Avatar
For a couple of years I was trying some kind of different idea/prototype about every two weeks or so. I still have a closet stacked full of experimental speaker enclosures collecting dust. It was great fun and I learned something. Now I like the sound of open baffle until I find something even better.
Old 23rd November 2012, 02:56 AM   #30
VaNarn is offline VaNarn  Australia
An interesting material called XBOARD PLUS PANELS ,has appeared recently and in its' thickest form offers a very high stiffness with a very low transmission of sound through the material.In Melbourne it is being tested in a a 650 litre vented enclosure matched to a modified Altec Lansing 15'' woofer with an ESS HEIL AMT in a two way system.The supplier of the panels is SHARP PLYWOOD in Queensland, for those who might wish to have more information.
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 7 25th July 2010 01:32 PM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Speaker damping: Foam or expanding foam akunec Multi-Way 2 16th September 2005 06:26 PM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
