Foam Core Board Speaker Enclosures?
Old 16th April 2018, 01:41 PM   #2971
silasmellor is offline silasmellor  Denmark
I've only drilled it, it gets very messy quickly! If it is for driver cutouts i would just do several passes slowly with a sharp knife to keep the circle neat. If you need rebates, sandwich two layers of foamcore and cut the outer face according to the driver outer diameter. That's what i did for the Mar-Ken's and it worked nicely.
Old 16th April 2018, 03:11 PM   #2972
gkh is offline gkh  Austria
gkh's Avatar
Silasmellor,
thank you for your quick response!
What do you mean by "it gets very messy quickly"?
Old 16th April 2018, 03:41 PM   #2973
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
If it's anything like cutting it with a power saw, he means that little pieces start flying everywhere and the cut edge is as jagged as sharks teeth.
planet10 needs your help:
Let's help Ruth and Dave
Old 16th April 2018, 03:49 PM   #2974
Speakerholic
Cal Weldon's Avatar
Originally Posted by xrk971 View Post
how much mass (if any) to add to the PR.
Hi X,
Thanks very much as always for your offer(s).
I think at this point I am simply winging it. I have a pretty good idea about the required box and also have a good feeling about the PR's. I wasn't looking to ruin the woofer by altering it so I looked around and found these. Just had to blow the dust off them. The size, cone travel and mass all seem about right. I am hoping to get these together in the next day or so and will know rather quickly if they are a success. They won't be a permanent speaker, just another Calsperiment.
Hope other things in your life are progressing as you hoped.
Cheers.
Old 16th April 2018, 04:25 PM   #2975
Exactly what Cal said
Old 16th April 2018, 04:45 PM   #2976
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
The two layer rebate is a great trick and what I do all the time. FWIW, the 3/16in thick foam core in the US is exactly the right depth to flush mount the bezel of most drivers: A7.3, 10F, TC9FD, RS100, B80, etc.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 16th April 2018, 06:43 PM   #2977
Speakerholic
Cal Weldon's Avatar
I won't be able to rebate the drivers as they are mounted to laminate flooring.
I also noticed my knife cutting skill goes way downhill when I want to see the results quickly, so caulking is going to be my friend here.
Old 17th April 2018, 03:41 PM   #2978
gkh's Avatar
Silasmellor, Cal:
Flying dust shouldn't be a problem as this small CNC router has an integrated dust extraxtor
Jagged edges on the other hand would be a real problem, but there are router bits on the market wth more than two cutting edges, and with up to 24.000rpm I really wonder...
I came up with this idea as my right hand is nearly without any feeling, and my cuts show this more than clearly.
Old 17th April 2018, 03:47 PM   #2979
jwjarch is offline jwjarch  United States
jwjarch's Avatar
GKH,
I've had success routing 1/2" foam-core with a spiral cutting bit and a Jasper circle jig. The edges were perfect. I also had my dust collector on to keep a good percentage of the dust down. I can't speak for the 3/16" foam core but I think it's worth a try. Material is cheap.
Old 17th April 2018, 03:49 PM   #2980
gkh's Avatar
Jwjarch,
could you please post a picture of your router bit?
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
