Foam Core Board Speaker Enclosures?
Old 21st February 2018, 04:28 PM   #2931
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
You should make the Trynergy - tractrix FAST synergy with TC9FD and some 6in woofers. It’s one of those best sounding speakers I have ever heard.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 21st February 2018, 04:48 PM   #2932
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
Wow. Those are nuts. Do they require active EQ to work well? I don't have any sort of DSP and have been avoiding getting one, mainly due to analysis paralysis keeping me from choosing something that is affordable and works well.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 21st February 2018, 04:53 PM   #2933
overtheairbroadcast is offline overtheairbroadcast  Canada
YouTube
This guy's videos up in the link there and his "foam core basics".
I saw his videos and went from a cheap dollar store breakaway knife to digging out my old Xacto with a #2 blade (probably could just have gone with a stronger and wider OLFA, but I had the Xacto already). Makes a big difference and knowing how deep to and how to cut versus tearing away with a dull edge. Always sharp makes it easier.
Old 21st February 2018, 05:47 PM   #2934
Got Foam?
xrk971's Avatar
Get a $80 miniDSP and some cheap $5 Class D amps to use as active outputs from the miniDSP. It will seriously change your life and what you can do with speakers. I did that exclusively and it was easy to get superb results. I play with passive XO's now because I like to build amps and single amps need passive XO's.
You need the calibrated UMIK-1 too to make any use of your infinite tuning abilities. It's all menu driven point and click interface. Once uploaded to miniDSP, it holds the settings without PC connected.
Old 21st February 2018, 11:28 PM   #2935
scott68 is offline scott68  United States
I agree with XRK and would suggest that since you will be using a PC to setup the miniDSP, why not go all the way and use the free APO Equalizer with the free "Peace" interface. I have a small windows laptop and a tablet that I use to run this easy to use graphic and parametric EQ with low and high shelf's, 31 bands that you can adjust or change the frequency's Q, 7 channels, each with there own equalization, many filters: The list is endless. Did I mention that is free and in 15 minutes you can start using it.
Old 21st February 2018, 11:33 PM   #2936
Here are a couple of pictures
Old 21st February 2018, 11:49 PM   #2937
Got Foam?
xrk971's Avatar
Those are great features to have but first thing is to get the speaker frequency response flat and phase flat and step response a triangle. Then all the other stuff can begin.
Old 22nd February 2018, 02:10 AM   #2938
HammerSandwich is offline HammerSandwich
Or you could build even more amps.
EQ APO can handle all of that, including running filters exported from REW & Rephase. For anyone with enough channels of reasonable-quality output, free software's an excellent to get your feet wet.
Old 22nd February 2018, 02:19 AM   #2939
Lingwendil's Avatar
The idea of a whole rack of DIY tube amps just to run my future multi-way builds gives me a stiffy for sure, never a bad time to build up more amps of various sizes
I wanted to build up a five channel amplifier for home theater system fun anyway, might as well make a few stereoblocks in anticipation of multiple driver projects.
I'm not into class D stuff, but do have piles of LM4780, 3886, and some PCBs for them lying in a box somewhere.
Old 22nd February 2018, 04:45 AM   #2940
Got Foam?
xrk971's Avatar
Use Class D to verify the miniDSP settings and XO design in software, if sounds and measures reasonably well, then invest in good Class AB or Class A amps to replace the $5 Class D. Even $5 TDA7498 can work well for proof of concept.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
