Foam Core Board Speaker Enclosures? - Page 21 - diyAudio
Old 1st December 2012, 05:01 PM   #201
Speakerholic
Cal Weldon's Avatar
First impression...
Not the end all but WOW!
planet10 needs your help:
Let's help Ruth and Dave
Old 1st December 2012, 05:12 PM   #202
xrk971 is offline xrk971  United States
xrk971's Avatar
Originally Posted by Cal Weldon View Post
First impression...
Awesome! That was how I felt when I first listened. What kind of music are you testing it out with? I can only imagine how much better yours sound given the larger full size cabinet, and the tricked out drivers.
I was right when I said you were days away from a first sound...
Does this put to rest the myth that you need to use plywood or mdf for speaker to sound fantastic?
Congrats again!
Old 1st December 2012, 06:01 PM   #203
Speakerholic
Cal Weldon's Avatar
Thanks to you xrk. I've mentioned it before but it bears repeating. If it weren't for you, this wouldn't be happening. I have thought about that horn for years but always dismissed it. Now I have it. These babies may get some extra treatment over the next little while. I am thinking of framing it and running grill cloth along the edges to hide the ugly bits. That might be just the ticket. Lord knows I have so many 'test' cabinets that I owe myself a nice set.
Man these are really something. Close your eyes and you are listening to a much larger woofer. I've had that experience a number of time including the CSS EL70 in a planet10 MKIII Frugel horn, but this is almost overwhelming. I am going to have to move them away from the wall as for the first time in my life I am using a Fostex driver and the vocals are recessed. No kidding, this is ridiculous. I have only medium stuffing in and around the driver so I may want to add more depending on what happens when I move them to a new location.
Old 1st December 2012, 06:28 PM   #204
xrk971's Avatar
Cal,
You are the man! I'm glad it all worked out for you Cal, and thanks for having the gumption to try it. I am glad to have been able to make this once elusive speaker, more accessible. Thanks for the kind words.
I guess these are pretty special to make it past test cabinets to getting framed and dolled up with grill cloth? Yes, that is funny to hear that a Fostex has underwhelming vocals drowned by prodigious bass. Rather than moving from walls as these are wall mount speakers, probably dense stuffing In speaker chamber, with more in channels will probably solve it. I was lucky with my Vifa's the balance between bass and mids was good to go - probably because they are smaller with Fs of 120 Hz and my channels are shorter. I wish I could hear yours.... do you have a nice digital recorder with xy mike to record sample of what it sounds like? I may do the same and we can swap listening experiences, albeit, can't be the same as room acoustics and our ears play a big role, I am just curious about the bass.
I know what you are gonna be doing with your free time in the next few days... trying all sorts of different songs to see how they sound, and finishing them off to look good enough to hang in your bedroom. I hope SWMBO will be pleased - as I have said before these babies have potential for high WAF.
Xrk971
Old 1st December 2012, 08:35 PM   #205
cochleus's Avatar
Originally Posted by xrk971 View Post
What is the new idea? We are all in suspense... Maybe a snail shaped horn using Fibonacci's golden ratio?
Ahh...the Fibonacci Sequence...hmmm, that does appear in acoustic math. I built some waveguides that used the ratio. My philosophy is to not proceed with a prototype unless I have a mathematical model first. Good luck with your experiments.
As to my idea...for the last month or so I have been thinking of ways to add a "baffle" to the rear of an [open baffle] speaker panel to increase the bass response through time delay of the rear wave field. The deflecting "cornu" spiral with some modifications looks promising to me.
"It always comes down to the best guess..."
Old 1st December 2012, 08:45 PM   #206
xrk971's Avatar
You want to combine the Cornu spiral with the woofer of an OB to get time delay for the back propagating wave? That would be one huge spiral. From Cal's listening experience you don't need a woofer, just use the Cornu with main mid/high driver away from wall and you get your 'OB'.
Old 1st December 2012, 09:03 PM   #207
cochleus's Avatar
My direction is to try to stay full range or single driver. The spiral rear baffle would save space and still provide time delay. That is opposed to having wide side-wings that take up space. I would also modify the spiral to try and avoid strong standing wave patterns. I was actually encouraged when Cal said it had strong bass.
Old 1st December 2012, 09:12 PM   #208
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
At art supply stores there is also 1/2" foam core.
Not cheap really but twice as thick which is 4x or 8x as stiff- you engineers will tell me. Might be good for the front and back panels if light weight is a factor.
There's also something called Gatorboard which has phenolic impregnated paper on each side. Very stiff! but quite expensive and a $%^%^$# to cut, so not recommended. Flexy ply for the curves and 1/4" ply front and back panels would be pretty stiff- that spiral has walls pretty close together!!
After getting the perfect design using foamcore first of course..
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio [/B]
Old 1st December 2012, 10:48 PM   #209
xrk971's Avatar
The completed spiral is actually very stiff and strong for how light it is because it resembles honeycomb panels where all the material is far out at the edges and the core is mostly air. I think it may be the lightest of all speakers that have this much bass. The foam core ones can literally be thrown like a pizza box and fly. The nice thing about being light is it's very easy to hang anywhere, don't need to find studs or use expansion bolts. Just a nail or screw anywhere and no fear of it hurting the kids or pets if it falls.
Old 1st December 2012, 10:54 PM   #210
diyAudio Editor
Variac's Avatar
yeah most doors in houses in the US have thin luan ( a very soft wood) faces with corrugated cardboard stiffeners between them. Wood around the perimeter of course. In fact "doorskins" which are just the wood face are very cheap and might be perfect for the fronts and backs of the speakers.
MJL based calcs would be interesting..
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
Copyright ©1999-2017 diyAudio
