Foam Core Board Speaker Enclosures?
Old 10th December 2013, 04:25 PM   #2031
bcmbob is offline bcmbob  United States
You are completely out of control. That's fantastic.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 10th December 2013, 07:47 PM   #2032
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Default Cochlear sealed TL - Build Completed
This things sounds great! I am surprised how much bass actually comes out of the direct radiator cone. The mids and highs are exceptionally clear - the transparency and detail are quite astonishing with the few test tracks I have listened to. I like how it sounds and I think when in stereo the sound stage will be very nice.
It is 12 in tall x 5 in wide x 9 in deep. Here it is sitting on top of the old Yamaha RX360 amp with a TPA3116D2 and a TPA3110D2 (in blue snap top lid box). Second photo is the back side so you can see the nice curves that the foam core can make.
Old 10th December 2013, 08:23 PM   #2033
IG81 is offline IG81  Canada
IG81's Avatar
Pretty neat! Do you have a mic for some quick measurements? I'd like to see a near-cone plot for that one. How does it compare to the small Karlsonator?
I haven't done much enclosure experimentation lately, but had the FF85WK -wave pipe trotting back in my mind lately for some reason. The foamcore prototype I made almost a year ago showed some promise. I'm pretty certain what I was going for worked to some extent, but I'd have to compare with a more standard pipe to see if it offers any advantages.
IG
Old 10th December 2013, 11:59 PM   #2034
Got Foam?
xrk971's Avatar
I will try to get a measurement in next few days but first have something to try...
Remember the tractrix foam core horn I made a while ago?
Old 11th December 2013, 01:47 AM   #2035
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
That speaker looks AWESOME!
Old 11th December 2013, 02:13 AM   #2036
IG81's Avatar
Yeah I do, tried it much yet? I've made a Tractrix of my own as well a while ago. Paper petal variety:
IG
Old 11th December 2013, 02:19 AM   #2037
Got Foam?
xrk971's Avatar
Default Cochlear w/ Tractrix
BP1Fan,
If you think that looks good, check out what it looks like with a front tractrix horn - now were cooking with fire! The sound is very wide dispersion and makes the driver appear substantially louder - although I detect some horn coloration as this was not at all optimized.
Old 11th December 2013, 02:31 AM   #2038
Got Foam?
xrk971's Avatar
Default Cochlear sealed TL- near cone measurements
IG,
I have some near cone measurements (1 in from cone). My setup uses a Panasonic WM61A capsule and the built-in mic input on the laptop which was designed for video conferencing etc so I think it has a low pass filter at around 5kHz. I am pretty sure the speaker has plenty above this sharp falloff. What I can measure though is very flat - as expected from a cochlear spiral with stuffing. There appears to be NO reflections whatsoever and the response is amazingly flat. The bump at 30 Hz is the hum from the HVAC. The drop near 330 Hz probably corresponds to the closed-ended TL length of 36 inches (1-Lambda of 312 Hz)? Look at how clean the impulse response is, and the low THD of less than -40dB, and the nice -20 to 20 deg linear variation in phase.
Old 11th December 2013, 03:12 AM   #2039
MisterTwister is offline MisterTwister  Tibet
xrk971, do you have impedance measurements from that speaker? thanks
Old 11th December 2013, 03:18 AM   #2040
Got Foam?
xrk971's Avatar
MisterTwister,
No, I don't have a way to measure impedance - as it is a sealed alignment, I would imagine it is a single peak somewhere near the tuning freq of the TL at about 300 Hz.
X
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
