Foam Core Board Speaker Enclosures?
Old 5th June 2013, 01:28 PM   #1851
bcmbob is offline bcmbob  United States
OOps! That's not the K-horn - it's called the TH-18 sub. (see link in post #1849)
I'm thinking anything from the drivers purchased for the DNA all the way up to some 10" woofers with stamped frames. A 4" to 6" probably be best for FC, but I just guessing.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 5th June 2013, 03:16 PM   #1852
GM is offline GM  United States
GM's Avatar
Do a search for the Replicon Horn, it does a pretty good job of designing a traditional BLH [aka BVR, 'scoop' bin] using T/S, so I assume anyone with decent math skills [not me] can rearrange the formulas to get the driver specs.
Hopefully, someone will mod its Excel SS calculator to include this reverse engineering and post it somewhere for downloading for us math challenged folks.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th June 2013, 07:01 AM   #1853
xrk971 is offline xrk971  United States
xrk971's Avatar
Default Tractrix front horns in FC
I finally finished the tractrix front horns. It was easy to make using the 'score the concave curved side' technique. The hard part was coming up with the pattern - I did it with regular paper by trial and error to get close, then the final foam still needed some trimming. The resulting horn has a 4 in x 4 in throat and a 13 in x 13 in mouth with a 4.5 in length. I did a quick test by taping it to the front of the FH3-inspired FC speakers and wow, you really notice the gain in mids and highs from a distance away. Also the presentation was wider, you can walk around more and still hear the highs clearly. The trick is to make the brace first with the correct profile, hot melt the horn panel to that first. Make 4 of those sets and then glue the seams together one by one. If anyone is interested in the pattern, I can scan that and post it.
Old 27th June 2013, 07:21 AM   #1854
prezden is offline prezden  Canada
x- they look great. you have become a true foam core sculptor
Old 27th June 2013, 12:04 PM   #1855
xrk971's Avatar
Thanks Prez! You are the master of the beautiful Cornu, and by all accounts you have made more of them than anyone - making you the master Cornu FC sculptor!
How are those W4 TB Bamboos in the 22 in x 4 in Cornus doing? Do you ever plan on making measurements using an inexpensive mic and Holmimpulse or something similar? I am curious to see how my sims of the Cornu match with measurements.
Old 27th June 2013, 02:20 PM   #1856
IG81 is offline IG81  Canada
IG81's Avatar
Cool horns! A slightly smaller version of these might be perfect for my FF85WK in the small BLH. The square-conical horns I had on these were too aggressive at 40 (!). I bet these tractrix would not choke the VHF output as much too.
IG
Old 27th June 2013, 02:25 PM   #1857
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Nice looking horns X. The joints look like they came out really well.
planet10 needs your help:
Let's help Ruth and Dave
Old 27th June 2013, 02:57 PM   #1858
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
That's a beautiful looking horn!
Old 27th June 2013, 03:11 PM   #1859
KLBIrd is offline KLBIrd  United States
KLBIrd's Avatar
How about providing a dimensional drawing of that nice horn?
Old 27th June 2013, 03:12 PM   #1860
xrk971's Avatar
IG
I remember your horn. When you say too aggressive, does that mean there is HF falloff? It's easy to scale plan with printer prior to cutting to get your size.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 08:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 02:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 09:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 09:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 06:05 AM
