Foam Core Board Speaker Enclosures? Foam Core Board Speaker Enclosures? - Page 169 - diyAudio
Old 29th April 2013, 02:38 AM   #1681
chandra53 is offline chandra53  United States
Oops - it looks like I posted this in the wrong thread. I've reposted it in the cornu spiral thread. Sorry about that!
Old 29th April 2013, 04:13 PM   #1682
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Part of the idea behind 'corners' in the spiral is that it will damp the higher frequencies better. I'm sure Mr. C experimented with true spirals before deciding on the Cornu.
planet10 needs your help:
Let's help Ruth and Dave
Old 29th April 2013, 05:25 PM   #1683
bishopdante is offline bishopdante  United Kingdom
Originally Posted by sreten View Post
For laminates the core isn't really the issue. Layered cardboard
varnished with polyurethane is very strong and light, and some
cheap furniture (storage boxes mainly) is made this way.
For paper foam board I'd suggest a varnish layer on the outside and
when its very near dry adding a layer of heavy duty aluminium foil.
Or varnish and let it dry, then add the foil with contact adhesive.
rgds, sreten.
Hi, Make such a laminate and you'll soon work out what it does, rgds, sreten.
Outside dual foil layers stiffen softer laminates by a very large amount.
As exemplified by the leak sandwich advert, where a man stood on a cone from the leak sandwich speaker, which was constructed from aluminium laminated over foam core.
Could also try gluing bits of stainless steel sheet to both sides.
There are also various heavier duty versions of foam core cardboard, such as foamex.
Foam is also pretty easy to CNC, so one could potentially cut the form and then spray it with a fiber impregnated resin and / or apply a metal skin.
Old 29th April 2013, 05:52 PM   #1684
xrk971 is offline xrk971  United States
xrk971's Avatar
Once upon a time... Surfboards are made of very soft sculpted foam covered with fiberglass and epoxy or other resin. They are quite stiff in bending mode but can be fragile in localized compression (aka dings).
Old 29th April 2013, 07:52 PM   #1685
motrctyman is offline motrctyman  United States
Ok, getting closer to having a RatShackFoamcore playing. Found some extra time and got some extra bracing put in, a second layer for the baffle speaker wire and stuffing, then glued on the other side. Waiting for glue to dry sucks.
Old 29th April 2013, 08:34 PM   #1686
Speakerholic
Cal Weldon's Avatar
I agree, that's why I try and time it so I am gluing the last piece on just before bedtime.
Old 29th April 2013, 09:18 PM   #1687
xrk971's Avatar
Motownman,
Very nice work! Can't wait to see you fire it up.
Old 29th April 2013, 10:18 PM   #1688
Speakerholic
Cal Weldon's Avatar
Aren't they still? Heck, I remember when they were about twice as long and made of wood.
Am I dating myself?
EDIT: I see you said 'are' made not 'were' made.
Old 29th April 2013, 11:50 PM   #1689
xrk971's Avatar
Once upon a time I used to surf...
Old 30th April 2013, 12:21 AM   #1690
Speakerholic
Cal Weldon's Avatar
I still do. Right now I'm here but in a couple minutes I be surfing some other site.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
Copyright ©1999-2017 diyAudio
