Foam Core Board Speaker Enclosures?
Old 2nd March 2013, 02:17 PM   #1421
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
My favorite is the bookshelf press full of books as used by Sebastian on the wooden Cornu build.
Hey whatever you have around. The problem with cinder blocks is they are not useful for anything else when done with clamping (other than building brick and mortar stuff or to make stands for a dorm room shelf).
Old 2nd March 2013, 03:28 PM   #1422
Carlp is offline Carlp  United States
Originally Posted by Cal Weldon View Post
The light is getting brighter. If it works remains to be seen. Tomorrow is the point of no return when the backs go on.
P1 - channels completed, before caulk seal.
P2 - filets placed.
P3 - filets clamped.
Fingers crossed. wish me luck.
Man, that almost begs for a clear baffle. Nice work, Cal.
Old 2nd March 2013, 03:32 PM   #1423
Oh, c'mon. I'm using my cinder blocks for a backyard maple sap boiler...so no speaker gluing for now.
Old 2nd March 2013, 03:33 PM   #1424
bcmbob is offline bcmbob  United States
.....The problem with cinder blocks is they are not useful for anything else when done with clamping (other than building brick and mortar stuff or to make stands for a dorm room shelf).
That really depends on the depth of you FC syndrome. Could lead to a whole new project. Remember??
Two fresh blocks per FC project and soon....
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 2nd March 2013, 03:42 PM   #1425
Cal,
Just to be sure - your efforts are really impressive. Can't wait to hear about the results. Only having a little fun at your expense.
Bob M.
Old 2nd March 2013, 03:43 PM   #1426
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Yet another note to self: Cut the pieces to size before gluing together. Yellow glue is hard to cut with an Olfa knife.
Originally Posted by guangui View Post
Cal,
Have you ever thought of buying 4 to 6 cement blocks
Yes but like most things, I use them up on something. In this case they became base weights.
planet10 needs your help:
Let's help Ruth and Dave
Old 2nd March 2013, 04:00 PM   #1427
Cement is good !!! Made these last summer for a pair of 8" monitors from the PE forum. Have all the components - just need Spring to come to get them unstuck, thawed, cleaned up and painted
Bob M.
Old 2nd March 2013, 04:15 PM   #1428
KLBIrd is offline KLBIrd  United States
KLBIrd's Avatar
Here is another iteration of foam board construction with foam stands. Two Audience A3 Full range speakers per side in a traditional full SD, 1/4 wave at 40Hz. No tweeters needed here and the bass is that typical warm type that only TL can provide. The imaging is also stunning. Still need to do some measurements. Foam is a cheap prototyping material and these enclosures could be fabricated with 1/4" or 1/2" plywood and still maintain the narrow profile.
Old 2nd March 2013, 04:17 PM   #1429
Beautiful !!!
Looks like those drivers are gone from PE. Think 4 of the Vifas would work?
P.S. Sent Paul K. a link
Bob M.
Old 2nd March 2013, 04:23 PM   #1430
Speakerholic
Cal Weldon's Avatar
Those look great Ken.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 08:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 02:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 09:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 09:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 06:05 AM
