Old 1st March 2013, 07:49 AM   #1411
xrk971 is offline xrk971  United States
xrk971's Avatar
Guangui,
Those look good in that finish and I am happy the sound worked out even though this was designed for the much more expensive FF85wk. Those are the same binding posts I use!
Old 1st March 2013, 10:28 AM   #1412
guangui is offline guangui  Puerto Rico
Originally Posted by xrk971 View Post
Guangui,
Thanks! I am very happy with the result of using the inexpensive TB W3-881SI.
Old 1st March 2013, 03:55 PM   #1413
Speakerholic
Cal Weldon's Avatar
Originally Posted by zayne742 View Post
I cut behind both sides of the paper, folded them over, cut out the foam, and then glued the paper to the next strip.
Hi Zayne,
That's a great idea., I will have to remember that for next time. Next time? OMG - Gulp!-
I have now completed the internal channels and after cursing the caulk up and down, I decided to read the label. You know how you assume sometimes? Turns out this isn't urethane, it's butyl caulk meant for gutters, not the stuff for vapour retarders, so I really did curse myself. If had only run to the store for some of that cheap acrylic latex stuff, I would be a lot happier.
So now I am ready to install the backs. Because this is a critical one to seal up tight I will employ the filet method where you glue down a thin strip of paper first to give me a level ledge onto which I can add a heavy layer of PVA for the bonding.
There is light at the end of the tunnel!
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 2nd March 2013, 04:02 AM   #1414
xrk971's Avatar
Looking good! I think it's going to sound awesome !
Good luck!
Old 2nd March 2013, 05:09 AM   #1415
grufti is online now grufti  United States
wombat
grufti's Avatar
Wow! Hoping for a tight seal!
Old 2nd March 2013, 07:12 AM   #1416
bcmbob is offline bcmbob  United States
Looks to me like a new page for the Rorschach test. If you see a snowflake you are normal and sane. If you see four tiny tubas you have an advanced case of FC syndrome.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 2nd March 2013, 07:30 AM   #1417
xrk971's Avatar
You mean Five tubas - I guess you have it worse than you think?
Old 2nd March 2013, 07:36 AM   #1418
Hey, leave me alone. I have a whole group of serioud mental conditions I have to deal with every day - one is numerical dyslexia.
Bob M.
Old 2nd March 2013, 11:53 AM   #1419
KLBIrd is offline KLBIrd  United States
KLBIrd's Avatar
Send a message via Skype™ to KLBIrd
It looks like a lab mouse run. Put him in the center and see which path he chooses. Hopefully it will sound as good as it looks.
Old 2nd March 2013, 12:44 PM   #1420
Cal,
Have you ever thought of buying 4 to 6 cement blocks at your local hardware or HD/Lowes? They are about $1.00 each, and will make a more balanced and even pressure press than your contraption. Though we know your chair press works as we have seen it previously in use.
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 7 25th July 2010 01:32 PM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Speaker damping: Foam or expanding foam akunec Multi-Way 2 16th September 2005 06:26 PM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
Copyright ©1999-2013 diyAudio
