Foam Core Board Speaker Enclosures?
Old 7th February 2013, 12:44 PM   #1261
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Originally Posted by Cal Weldon View Post
Holy cow it's Brian! How the dog and be devil are you man?
Hi Cal. I'm good. Glad to see you guys are still alive, kicking, and pushing the boundaries of DIY audio.
Originally Posted by xrk971 View Post
Bwrx,
I'm not sure what you mean about cutting out the are where the wall goes? You mean a slot? That's how the commercial Cornu is made with a slot on the middle separator panel.
Instead of a dado/slot/channel in the sides I just meant cut straight through the foam so you have a slot to put the wall into. It appears that I need to research the history of the Cornu a bit more.
I've used this stuff before to make architectural models and it's nice to work with. You can get fancy with tools that let you cut nice angles but as you have shown you can get great results with minimal effort just using a straight edge and a knife!
Brian
Old 7th February 2013, 03:47 PM   #1262
badman is offline badman  United States
badman's Avatar
Found a neat product- delayed cure epoxy. Looks like a full 30 min of open assembly time before the cure begins. Should be great match for foamcore builds.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 7th February 2013, 11:59 PM   #1263
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Hey X, What do you think about using some Iso or type IV EPS for making a tapped horn?
planet10 needs your help:
Let's help Ruth and Dave
Old 8th February 2013, 12:19 AM   #1264
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Cal,
I think it's a great idea and in fact I suggested it a few posts back. So did Kenlbird. It's pretty inexpensive and big. Use framing adhesive?
R-Matte Plus 3 R-3.2 1/2 in. 4 ft. x 8 ft. Foam Insulating Sheathing-754404 at The Home Depot
You can make a full size BIB for 8 in driver with it or a HT tapped horn sub.
Old 8th February 2013, 12:46 AM   #1265
Speakerholic
Cal Weldon's Avatar
Thanks X, I can get what I need through work. Forgive me for not noticing the tapped horn stuff. I would like to do a clamshell [isobaric?] style as I have 4 small woofers and room for only 2 cabinets. I will have to look through the threads to see if this is something you can do.
Old 8th February 2013, 12:49 AM   #1266
Speakerholic
Cal Weldon's Avatar
I found one but it didn't give me much so maybe I will start another thread. I think I am now in the wrong forum.
Cheers.
Old 8th February 2013, 01:07 AM   #1267
Got Foam?
xrk971's Avatar
When you say clamshell do you mean drivers are inside between two chambers with vent on one side? A 4th order bandpass sub cabinet?
I just designed one today with the Aura 6 in NS6 closeout woofers $9 ea. Flat bandpass from 40 to 100 Hz with 87 to 89 db efficiency in box 8 x 12 x 24 in. Perfect for foam sheathing.
Old 8th February 2013, 10:26 AM   #1268
zayne742 is offline zayne742  United States
Cal,
I really wonder if that will work, here comes Mr. Downer, all of the thick insulation I have used, usually the pink 3/4", has had a strange resonance. Now I did not use it for any cabinets, thought about it. But when handling it, it just seems like it's natural resonance would cause issues.
I hope I am wrong! If you get a chance go pull a piece off the shellf and thump on it a bit.
Fliping Switches, Pushing Buttons, and Turning Knobs.
Old 8th February 2013, 10:32 AM   #1269
Got Foam?
xrk971's Avatar
All materials have resonance, even foam core with paper facing and mdf. Use lots of bracing on larger spans.
Old 8th February 2013, 01:48 PM   #1270
GM is offline GM  United States
GM's Avatar
Will work best overall with high Q drivers to help damp their inherent 'ringing', but bracing goes a long ways towards stiffening it up if using a lower Q driver.
One of many published fun projects from the early days of engineered insulation board that helped fuel my interest in DIY speaker design: Weems Celotex TL - a set on Flickr
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
