Foam Core Board Speaker Enclosures?
Old 31st January 2013, 04:51 PM   #1161
ravener is offline ravener  Singapore
Ah realised I've been doing the calculations wrong.
The throat is the opening where the compression chamber connects to the horn right?
If that's the case, the formula would be:
fh = (c * S_throat) / (2 * pi * Vol_CC)
fh = (342m/s * 0.0035m^2) / (2 * 3.142 * 0.00154m^3)
fh = 123Hz
Old 31st January 2013, 05:59 PM   #1162
I guess it's time for me to sleep, made a mistake in the previous calculation, resultant fh should be 1233Hz.
How bout this for a change?
Tapering the end to close, and making the horn port(mouth?) wider.
Based on the dimensions of 21" x 13" x 3"(deep)
fh = (342m/s * 0.00464m^2) / (2 * 3.142 * 0.00034^3) = 743Hz
hmmm, doesn't seem to work, any suggestions?
Argh... hate the calculations. Guess I will just make a prototype and listen from there.
Old 31st January 2013, 06:25 PM   #1163
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Ravener,
According to your drawing in post 1162, the compression chamber would be approximated by a circular chamber of 3.6 in in diam by 3 in deep = 0.50 liters. The throat area I am guessing is about 1.75 in across x 3 in deep = 34 cm^2. (You have a throat that goes to nowhere, which I mistakenly thought led to an output).
So fh = (342 m/s * 0.0034 m^2)/(6.284 * 0.0005 m^3) = 370 Hz.
370 Hz is a little on the high side and it means that lots of mid-range will come out of horns and cause phase delay problems with your ears and ruin spatial imaging. You can fix this by expanding the driver chamber volume by adding a sub chamber beneath the main horn connected with a hole, or add raised (hollow) suprabaffle above where you mount driver to boost volume. Alternatively, the easiest fix is to simply clamp down on the throat area by a factor of 0.75x - put a constrictor plate there (1.3 in wide gap). The horn expansion you have is good - it will result in quite a bit of gain in the bass notes. The mouth area/throat area looks approximately 10:1 - so not bad.
Old 31st January 2013, 07:16 PM   #1164
Good to hear, I will adjust accordingly and build using this then...
Time for me to get some sleep, hopefully I can wake up early enough to go source for materials, and hopefully they are as cheap here as in the states...
Old 1st February 2013, 01:18 AM   #1165
IG81 is offline IG81  Canada
IG81's Avatar
More foam-core wackiness:
IG
Old 1st February 2013, 02:32 AM   #1166
Got Foam?
xrk971's Avatar
IG,
You beat me to it. Nice work I have been thinking about doing a front horn but in 8 segments and curving it. I have been looking at Tractrix profiles and such but haven't gotten to the point of cutting foam yet. I made a mock up in plain paper just to see if the segments bend and curve the way I intended.
How does it sound?
Old 1st February 2013, 02:59 AM   #1167
IG81's Avatar
Originally Posted by xrk971 View Post
IG,
How does it sound?
Not too bad. The small BLH counters baffle-step pretty well and upper-bass is even hot enough on certain material that I wanted to try a small front horn to lift midrange a bit. I just threw it together with no calculations, came out ~40, a bit too aggressive, did not have enough foamcore left to make a larger mouth. Gives ~6dB of gain from 400Hz to 4kHz, with some peaking on both ends of the BW. Also had to add a super-tweeter because it killed upper treble output.
IG
Old 1st February 2013, 09:14 AM   #1168
Got Foam?
xrk971's Avatar
IG,
6 dB is not too bad. Too bad it impacts the high bandwidth. With properly designed curved horn, can that impact be reduced? Something like tractrix shape is used on HF correct?
Old 1st February 2013, 09:35 AM   #1169
Hot day outside, just got home from shopping. Got myself some 5mm thick foam board, a glue gun, and gorilla glue to seal the top.
Shall rest a bit first and start after I had my dinner.
Old 1st February 2013, 10:49 AM   #1170
makingmoney is offline makingmoney  United States
Default Foam core Open Baffle computer speaker.
Below is a rough sketch.
Is there an OB 3" driver that would work well in this?
Maybe bass down to 100-200hz?
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
