Foam Core Board Speaker Enclosures?
Old 9th January 2013, 03:07 AM   #1051
xrk971 is offline xrk971  United States
xrk971's Avatar
Ok, where is a good place to get inexpensive wool felt then? Is there something magical about wool vs synthetic fibers for damping?
Old 9th January 2013, 01:42 PM   #1052
zayne742 is offline zayne742  United States
The stuff Planet10 and others are using is the ultratouch denim insulation. The company, bonded logic, has a dealer locator. HD has it online, Lowe's and menards may have in store.
I feel like a billboard...
Green building supply stores are carrying it also.
Fliping Switches, Pushing Buttons, and Turning Knobs.
Old 9th January 2013, 02:28 PM   #1053
xrk971's Avatar
Thanks for tip on the material Zayne. The Ultratouch denim is really cotton then. The latest build pics on the FH3 vs DTB appears to be using real thick wool felt. Where do you get that stuff? Is there an advantage of wool vs cotton vs polyester, and what about special microfiber polyester which has a very high surface to area ratio?
Old 10th January 2013, 06:24 AM   #1054
chazdrumzalot is offline chazdrumzalot  United States
For your viewing pleasure: Henkjan's desktop TL in foam board.
Compared to my cornus, these are much more quick-and-dirty, however I am much more pleased with the result. I'll definitely be making a real pair as soon as I am able.
Then again, what do I know?
Old 10th January 2013, 06:50 AM   #1055
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Somewhere in SE England.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th January 2013, 07:03 AM   #1056
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
inexpensive wool felt is an oxymoron!
Maybe it's the most expensive thing related to audio...
To have effectiveness it should be ...well, some of the most famous
enclosures adopt it ,mostly on the baffle.
Of course, using it to attenuate the back wave of the membrane
in a twisted environment brings results that cotton and synthetic fibre
don't show; it's related to the density/volume and the properties of wool
to convert pressure to heat.
Old 10th January 2013, 08:20 AM   #1057
xrk971's Avatar
Nice work Chaz! Glad it worked out for you, congratulations.
This is exactly what is so great about foam core speakers: you were able to determine that a design is worthy of pursuing in real wood quickly and cheaply. And it probably sounds pretty good even if you left it in foam?
What is it about the sound from this vs your cornu's that you like better in sound quality?
Old 10th January 2013, 08:24 AM   #1058
xrk971's Avatar
dave
LOL. You might as well have said New Zealand, known for its wool. The only time I have seen something like this in the States is sold as footbed liners for foul weather / fisherman boots.
I just saw a post under
Henkjan's TL thread where someone said they used a $1 polyester fleece blanket from dollar store as stuffing with good success.
Old 10th January 2013, 12:38 PM   #1059
makingmoney is offline makingmoney  United States
Is there much foam core "sound"? Honky, rattles or resonances? If your foam core looked better, would you use it?
Thanks!
Old 10th January 2013, 02:16 PM   #1060
xrk971's Avatar
For the Cornu and FH3-inspired horn (and all of my other foam core speakers), I do not hear any rattles or resonances of the foam cabinet itself. However, you can feel that the foam core is vibrating and thus, there is probably some low level acoustic output - but it doesn't seem to detract from the overall sound. Use of bracing is important, for the Cornu, the spirals act as bracing for the baffle. For other box shaped designs, I add bracing wherever the span feels like it is more than 3 inches. This helps keep the structure more stable and prevents it from resonating too much or collapsing if you push on the wall too hard.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 08:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 02:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 09:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 09:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 06:05 AM
