#991 | |
Do you or anyone with OB expertise have a suggestion as to how wide the OB should be for this line array, and should drivers be offset to one side slightly? Again, limitation is the width of the foam core stock, i would like to be able to make whole baffle with C channel sides out of a single 20 x 30 sheet per 6 drivers. I was thinking 16 in wide with 7 in deep sides ( wings). But if it would make it sound a lot better with much wider baffles, I could do that. It just starts to look too imposing and WAF goes way down... Last edited by xrk971; 2nd January 2013 at 09:23 AM. |
#992 | |
Like I said, I am trying to avoid making any sawdust...
#993 |
frugal-phile(tm)
It probably has cheaper drivers in it... and i'm sure one could find something better to scavenge an iPod dock from
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#994 |
#995 |
I've just been working on the push pull in my vector program and it's just too freggin big.
It wouldn't make sense for this driver.
I LIKE YOU
#996 |
Is the idea that one driver is mounted with cone into compression chamber and other face out in order to cancel driver hysteresis? Show me a sketch of the concept.
#997 |
#998 | |
The basic idea is to have a front loading horn coupled with a rear loaded horn. It's just for efficiency and getting the most low end that you can, also they are great for directivity. Well, to give you an idea of the size....think about the path length and mouth area for the conru, then add the front expansion as well. The design was kind of a large V on wall. Here, this is an example of a push pull. About the 5th post down. horn loading - Page 2 - pink fish media
I LIKE YOU
#999 |
Ok, one driver but horn on front and back. The real Cornu has options for a front horn, it is not too big. The non folded types are just too huge looking and would not work well in most homes with a spouse. It's just like the post in the link said, a non-folded horn is either a sign of celibacy or imminent divorce...
#1000 |
Lmao!
| Replace speaker foam with this odd material? | flyingsquirrelman | Subwoofers | 7 | 25th July 2010 01:32 PM |
| concrete board for enclosures? | alandarkdale | Multi-Way | 6 | 31st March 2007 08:35 AM |
| Speaker damping: Foam or expanding foam | akunec | Multi-Way | 2 | 16th September 2005 06:26 PM |
| Foam core construction for subwoofers | morbo | Subwoofers | 19 | 30th August 2005 08:09 PM |
| speaker foam | dave k | Multi-Way | 2 | 24th June 2003 05:05 AM |
