I'm very inexperienced when it comes to designing speakers - so I bought 6 3" FR for various practice projects.
2 of them I was going to use in some simple computer speakers but I added the 6" woofers so I could get free shipping, and thought they might work well with the FR in a 2-way setup. TB W3-881SI 3" - Tang Band W3-881SI 3" Speaker 299-113 Aura NS6-255-8A 6" - Aura NS6-255-8A 6" Paper Cone Neodymium Magnet Woofer 299-030 Most of the FAST projects (if I understand that term correctly) involve much larger woofers. I'm not expecting a ton in bass, so I figured the 6" would be fine. I'm looking to build something bookshelf size (maybe 9x15x8), but I'm not quite sure how to calculate the XO for such a project. I have the graph information for both drivers. Do you think this setup would sound fair? |
#2 |
just another
I'd say go for it if you want to learn something! I think you would have a lot of flexibility as far as where you cross them over and could experiment with crossovers probably from 300hz up to 3000 hz!
Tony. |
#3 |
Here you can get some inspiration:
Loudspeakers by Emil Attlid and forum.zelfbouwaudio.nl • Toon onderwerp - The Cooper - small and FAST (dutch) |
#4 |
I like that first design, pretty slick
so when figuring out a XO, I should do a high and low pass and wire them parallel? I didn't know if I was supposed to do something different because of the FR. Also, since there's a 5dB difference in the SPL between the two, should I add an L-pad? I found this page and was going to follow the instructions Introduction to designing crossovers without measurement does anyone know of an easy to use program that would general a graph for me? Thanks! |
#5 |
Honestly, as much of a graphs kind of guy I am, I would use a stock cross over and fiddle fart from there. That is unless you love to fiddle fart on a computer. I think you'd get bogged down and annoyed. More fun building and listening.
If you do want to take a stab at using software, most beginners like me use PCD. I can email you some files to try and play with if you're interested in seeing how it goes. |
#6 |
just another
It's a bit hard comparing those sensitivity figures because the tangband doesn't state whether it was 2.85V @ 1M or something else. However it is to your advantage if the woofer is higher sensitivity than the TB because if you put some baffle step compensation in it will bring the high end of the wo0fer down a bit but keep the bottom end up to the level of the TB. additionally if you look, the tb has a rising response (as does the woofer) so it is actually closer to that of the woofer at higher frequencies...
You should not end up needing any padding (at least on the woofer) I suspect. Tony. |
#7 |
frugal-phile(tm)
If the sensitivities are as published then an XO at or just below the baffle step should give a reasonable balance in-room.
So the wider your box, the lower the XO (and the bigger the parts if you go passive) dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
Thanks for the help! Too bad there isn't someone around like you guys I could intern with for a few days.
I noticed on the two designs Juicie posted, that each driver has its own compartments within the box, is this necessary? If so, when designing the box should I design it as two separate boxes? perhaps the woofer vented and FR closed? |
#9 |
just another
Yes you definitely need to have the two drivers isolated from each other, and I would think (without having done any modeling) that sealed would be best for the TB.
If you want some decent bass extention then vented should help on the woofer. Tony. |
#10 |
Do you personally think it's feasible to design a descent XO from the information provided, or will it sound off unless I test my specific drivers? I've seen a lot of posts by people who would never design something without testing the drivers at home first, and others who don't think its as important. I'm just curious about your philosophies on the matter (any who would like to chime in)
| 3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" | proxii | Multi-Way | 16 | 30th October 2012 12:43 PM |
| "BEST" Woofer 50Hz - 300Hz & Hi eff, maybe 15" ?? | bear | Multi-Way | 163 | 26th November 2011 12:45 PM |
| "Generic" 8" Sized Replacement Thin Wall Woofer Surrounds | DreadPirate | Multi-Way | 3 | 30th September 2009 07:40 PM |
| !st order series xover between 5"FR and woofer?? | johnmark | Full Range | 1 | 2nd May 2005 12:40 AM |
| WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer | gengis | Swap Meet | 0 | 17th March 2005 02:29 AM |
