What is a fullrange loudspeaker (an explanation)? - Page 8 - diyAudio
Old 11th November 2012, 01:10 AM   #71
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Why 40? It can't reproduce 5-string bass guitar, organ, piano.
And why 20 KHz? 8, 12, or 16 Hz may be sufficient. It may be enough to cover all specified range. For different classes of equipment different ranges can be specified. For bass guitar, for solo guitar, for pocket radio, and so on, ranges will be different. In "audio engineering profession" before engineering anything we have specifications. Without specifications it is not an "engineering profession", it is more like a hobby.
The Devil is not so terrible as his math model is!
Old 11th November 2012, 01:14 AM   #72
Melo theory's Avatar
Well, I think it should be the range of human hearing. So I guess it could be around 30Hz to 15kHz for most of us.
I LIKE YOU
Old 11th November 2012, 01:36 AM   #73
frugal-phile(tm)
planet10's Avatar
Originally Posted by Soundtrackmixer View Post
that would be a speaker that could reproduce 40-20khz with high output and low distortion.
Most domestic situations don't require really high output. And what kind of distortion? A single FR driver inherently lacks certain distortions introduced by any speaker with an XO.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th November 2012, 01:41 AM   #74
Originally Posted by Melo theory View Post
The thread is titled loudspeaker. Not driver.
That's what I thought......
Old 11th November 2012, 01:47 AM   #75
dave
I guess it could be also said that no single driver can cover a very wide frequency range like a three or four way can.
A single driver may lack certain distortions, but a single driver trying to reproduce deep bass, and high frequencies at the same time is going to have a bit of trouble.
Old 11th November 2012, 01:53 AM   #76
Their white paper recommends that you use a subwoofer for full and limited range speakers to extend the response to 20hz.
Maybe because that is the upper range of human hearing, and sufficient is not enough for some folks.
Hence why the audio professionals that created the different speaker distinctions did what they did. They set playback specifications for different size speakers in the studio environment.
Old 11th November 2012, 01:58 AM   #77
Moondog55's Avatar
Better add in "Sounds balanced" as I understand it we hear things differently when the sound has too much bass or too much treble, so if we are using a single driver then what I have read seems to say that if we want to include deep bass we need at the same time extended treble. So please give me some indication of where that desired bandwidth is. I personally find the "Telephone" bandwidth (300 - 3000Hz)acceptable for a mid range but definitely lacking in a so-called full range speaker.
I can how-ever quite happily listen to most reasonable 8 and 10 inch woofers run without crossovers and most of those stop around 7 or 8k. So is it 60 to 10,000hz or something a little narrower? 100 to 7500Hz??
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 11th November 2012, 01:58 AM   #78
sofaspud's Avatar
"Loudspeaker" is the general term for the electrical signal > sound wave device. Hence the sub-forums in the category.
But reading post #1 should make clear what was intended.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 11th November 2012, 02:16 AM   #79
frugal-phile(tm)
planet10's Avatar
40-20kHz (or 30-15k) is certainly doable with the best of today's FR drivers. What is usually given up is ultimate levels & dynamics. If you don't listen that loud then no big deal.
If you look at most multiways, few go down to 30 Hz, & a typical 1" dome is starting to fade above 15k. And each XO you introduce brings a whole slew of distortions.
dave
Old 11th November 2012, 02:51 AM   #80
Pano is offline Pano  United States
Pano's Avatar
Yes indeed. It's not that mysterious. Some folks are just too darn literal.
I need an explanation. Alexrmc92 Instruments and Amps 25 12th October 2011 07:51 PM
Srpp simple explanation joaquin Tubes / Valves 1 3rd October 2011 11:48 PM
Explanation wanted Hojvaelde Tubes / Valves 8 28th May 2011 02:37 PM
Schematic explanation johnnystulic2004 Solid State 1 20th October 2010 04:11 PM
Explanation for this problem? Rob11966 Tubes / Valves 4 22nd September 2007 04:39 AM
Copyright 1999-2017 diyAudio
