#61 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#62 | ||
Speakerholic
Taken from their site:
"The tweeter’s high-pass is, by design, a simple, single component network, a single polypro’ capacitor." Quite common when crossing over that high. Quote:
#63 |
Although you can find hundreds of arguments about whether inductors, resistors, and caps are audible, there is virtually no debate that the acoustic problems created by a cross over far exceed any problems created by the components.
In other words, that's all nice and dandy that they've avoided any parts in the signal save for a single cap, but they're not immune to the greater issue of what a cross over does. Lucky for them, it's so high it's likely inaudible and it is coaxed. |
#65 |
One transducer, covering the widest possible bandwidth 20Hz to 20kHz.
There are currently no covering the full bandwidth transducer. Frequency is complemented from the top (tweeter) or bottom (woofer). Have a nice day |
#66 |
Still, it can't cover the full bandwidth from say 0 Hz to 500 KHz.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#67 |
If I were to take the definition of full range from the audio engineering profession, that would be a speaker that could reproduce 40-20khz with high output and low distortion. A limited range speaker would span from 80-20khz with high output and low distortion, and a extended range speaker would be from 20-20khz with high output and low distortion.
This is how the audio engineering community makes its distinctions. |
#68 |
If we are talking about a crossoverless loudspeaker, the only true full range loudspeaker will be one that uses multiple drivers. A full range line array. That is 20Hz to 20kHz.
I LIKE YOU
#69 | |
Please let me re-repeat...
*That's "unrealistic" in an applications context, not a hi-fi context.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#70 |
The thread is titled loudspeaker. Not driver.
I LIKE YOU
| I need an explanation. | Alexrmc92 | Instruments and Amps | 25 | 12th October 2011 07:51 PM |
| Srpp simple explanation | joaquin | Tubes / Valves | 1 | 3rd October 2011 11:48 PM |
| Explanation wanted | Hojvaelde | Tubes / Valves | 8 | 28th May 2011 02:37 PM |
| Schematic explanation | johnnystulic2004 | Solid State | 1 | 20th October 2010 04:11 PM |
| Explanation for this problem? | Rob11966 | Tubes / Valves | 4 | 22nd September 2007 04:39 AM |
