What is a fullrange loudspeaker (an explanation)? - Page 6 - diyAudio
Old 9th November 2012, 01:41 AM   #51
So a 4" driver does move when fed 20hz. And there is output at 20k. Done!
Old 9th November 2012, 01:52 AM   #52
Originally Posted by Wavebourn View Post
You can use as many of them as wish
Hi Wavebourn,
Okay, interesting -- so widebander is a better term, because single implies "one only", and fullrange implies "all the frequencies." Wideband just means "broad range of frequencies" and I think it includes all the other definitions. So a "single driver full-range design" would be a particular type of wideband design.
Old 9th November 2012, 03:00 PM   #53
Speakerholic
Cal Weldon's Avatar
Originally Posted by Squeak View Post
Maybe so, but it's still not truly great at anything. That's my point.
Neither is a FR driver. That's my point. If there was a driver that could cover all the music and do it well, there would be no woofers and tweeters. Not gonna happen.
The best fullrange drivers however, used as single drivers, can truly excel at some types of material and/or in some environments/situations, and be merely adequate for others.
This sounds like a statement I should be making in this discussion.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 9th November 2012, 04:07 PM   #54
[An all-season tire is] still not truly great at anything.
Not true that such drivers cannot be truly great at some things. All drivers have limits so the performance ends up being implementation-dependent.
Random example: the Lowther field-coil. Definitely stunning in a good implementation (e.g., Elevenhorn 3-way horns, or the RMAF OB's with RAAL tweeters and servo subs). Widebanders are no different than woofers, tweeters, compression drivers, electrostatics, etc. -- there are limits to everything, and nothing does -everything- well.
Old 9th November 2012, 04:14 PM   #55
sofaspud's Avatar
My poll vote goes to Wavebourn.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 9th November 2012, 04:24 PM   #56
Hi sofaspud,
So you don't own a subwoofer?
Old 9th November 2012, 04:32 PM   #57
Speakerholic
Cal Weldon's Avatar
I agree, what I should have said is what you did below.
Old 9th November 2012, 04:39 PM   #58
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Yes., except your "20Hz" and "20k" do not matter. "Full" in terms of the specified range. It can be any. Like a coat made from a single animal skin. It's size can be any, but it covers the body of the given size. However, if you cover wider range it's problematic to find an animal to cover the "full" range by one skin.
The Devil is not so terrible as his math model is!
Old 9th November 2012, 07:37 PM   #59
Squeak is offline Squeak  Denmark
Squeak's Avatar
Which is almost exactly what I said if you read my post.
Only fullrangers does some things very well, argueably better than any other type of setup.
Old 9th November 2012, 09:53 PM   #60
I find full range drivers put the music back in the music. I have a pair of Jordan VTLs using the newer E100 drivers. They manage to do 40Hz to 20kHz and manage to sound great doing it. Plus they don't need alot of space around them, which is a bonus.
I had the opportunity to listen to the Zu Audio Unions at the Sydney Audio and AV show recently. They have a full range driver, but they intentionally cut it off at 12kHz and use a tweeter in a coax configuration to cover 12kHz to 22kHz. There is apparently no crossover to get in the way. I mention the Union, because despite it technically using 2 drivers, I would still consider them to be a full range speaker.
Perhaps it would be better to say that it is a speaker that projects music from a single point?
I need an explanation. Alexrmc92 Instruments and Amps 25 12th October 2011 08:51 PM
Srpp simple explanation joaquin Tubes / Valves 1 4th October 2011 12:48 AM
Explanation wanted Hojvaelde Tubes / Valves 8 28th May 2011 03:37 PM
Schematic explanation johnnystulic2004 Solid State 1 20th October 2010 05:11 PM
Explanation for this problem? Rob11966 Tubes / Valves 4 22nd September 2007 05:39 AM
Copyright 1999-2017 diyAudio
