Little DIY back-load horn for FF85WK
Old 3rd November 2012, 03:51 PM   #1
IG81 is offline IG81  Canada
IG81's Avatar
Default Little DIY back-load horn for FF85WK
Despite not ideal specs as a horn driver, I wanted to try the FF85WK in a BLH, with the intent to make it sound "bigger" and to be used on its own. Here's what I came up with:
They sound pretty good! The back-load horn does its job to fight-off baffle-step in order to keep sensitivity up. Bass is strong and fairly "flat" down to ~75-80Hz and it's useful down a bit below that, but the cutoff is steep under there though. They are roughly 4-5dB more sensitive than a Minimus 7 measured next to them and sound better by far. Tonal balance is good, leaning a bit on the bright side, but it's not a bad thing considering the FF85WK's good behavior up there.
They won't do stadium levels naturally, but are very good within their SPL range, which is enough for my small room. They can put out some fairly strong transients on sparse material. They have to be on the floor, or at least very close to help give some LF support. Sitting in a low-boy chair or just a mat on the floor enhances the bass and gets my ears closer to driver level. A bit of back-tilt helps for the latter otherwise.
IG
Old 3rd November 2012, 04:15 PM   #2
zman01 is offline zman01  Bangladesh
IG81,
Interesting challenge you took and cute BLH! You mentioned small room - I see some BIG speakers behind the horns....?
Old 3rd November 2012, 04:22 PM   #3
IG81's Avatar
Originally Posted by zman01 View Post
IG81,
I am a man of contradictions. The big ones are for early evening, the BLH for late-evening and the Sony MDR-7506 for night time. The TD15M is somewhat over-damped in the 5.0cf box tuned to 32Hz, so it works in the small room. I thought, why not go for a 3" after these 15" in the back? I like to DIY and want to try as wide a spectrum as I can too.
IG
Old 3rd November 2012, 08:44 PM   #4
cross reference is offline cross reference  United States
How did you figure out what size to build the horn box? Also how did you know were to put the spacers inside the box to get the most out of this driver? jm
Old 3rd November 2012, 08:52 PM   #5
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Excellent job on the back horns! I too enjoy a large and small system.
Large: 15" H-frames with a 12" wide range driver and helper tweeter.
Small: 4" Fostex 127e or 5" Dayton fullrange driver in BIBs (which barely take up any floorspace at all).
Totally different sound for different moods. Both systems sound GREAT!
Old 4th November 2012, 01:42 AM   #6
IG81's Avatar
I used Hornresp to model it. I also left some provision to adjust things like the compression chamber volume and the throat area, measured and evaluated subjectively, what I preferred was not necessarily what simulated best.
Thanks! I like to enjoy as many aspects of audio as I can.
IG
Old 4th November 2012, 01:56 AM   #7
Melo theory is offline Melo theory  United States
Melo theory's Avatar
Shweet!
Those look familiar
I LIKE YOU
Old 4th November 2012, 01:29 AM   #8
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
those just look too cute.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 4th November 2012, 08:55 AM   #9
ODougbo is offline ODougbo  United States
Yes very interesting! Looks bigger than a 83mm speaker, must be the tall cabinet.
Did you buy the drivers through P10? His "treatment" makes a huge difference; way better imaging and a "matched set" sound.
(Pic - Loner set of FF125WK drivers from P10)
It be great if somebody could design a BLH for the FF125WKs.
Old 4th November 2012, 12:02 PM   #10
IG81's Avatar
I got the drivers from Solen, I don't live too far from them.
IG
Little DIY back-load horn for FF85WKHide this!Advertise here!
fostex recomended backloaded horn design for ff85wk soundnovice Full Range 11 3rd October 2012 04:28 PM
Is this a back-loaded horn? zcables Multi-Way 3 17th September 2012 04:48 PM
back loaded horn nige838 Full Range 4 21st October 2010 12:33 PM
DIY Back Loaded Horn - Dallas III for Fostex 206E jasonlky Full Range 46 6th April 2008 11:50 PM
Back Load Horn Questions serenechaos Full Range 2 12th March 2005 10:32 AM
Copyright ©1999-2017 diyAudio
