Best Full Range Driver for Mini Monitor Size HT Use - Page 6 - diyAudio
Old 31st October 2012, 12:21 AM   #51
Those look great... congrats Dave and Chris!
Old 31st October 2012, 12:33 AM   #52
frugal-phile(tm)
planet10's Avatar
Those were a surprise from Bernie & myself for Chris,
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st October 2012, 05:17 AM   #53
zman01 is offline zman01  Bangladesh
Dave,
Very nice work - both the drivers and cabinets look great - kudos to you and Bernie! Chris should be a happy man.
Thanks Dave, I'll be looking forward to that test.
ve also been looking at those Bamboo cutting boards. Have you considered those before? I'm sure you have.
I've been thinking the same - but pretty expensive and 1/2" is the max thickness I am finding.
Old 31st October 2012, 10:10 AM   #54
DYNABLASTERTUNERS's Avatar
best drivers for HT use are Tang Band flatcones
some of my Designs www.dynablaster.deviantart.com/gallery
Old 31st October 2012, 01:39 PM   #55
I recommend you do some reading about working purpleheart before you get seduced by the appearance. It's nothing like working bloodwood.
In my experience, purpleheart is hard on the tools and hard on the woodworker.
I was thinking Purpleheart from South America.... I've used Bloodwood from the same continent before..... pretty stuff. Finding enough of it is the hard part.
I've also been looking at those Bamboo cutting boards. Have you considered those before? I'm sure you have.
I was so much older then, I'm younger than that now.
Old 31st October 2012, 09:25 PM   #56
That was pretty much my experience with the bloodwood. It's incredibly hard, waxy and dense, but brittle at the same time. Wore out some nice Porter Cable tools on it, the dealer could not believe it. It also burns when routing pretty easily due to the above factors. I found going very slowly and backing off a lot giving the tool time to breathe helped.
I'll follow your advice and read up.
Old 31st October 2012, 09:39 PM   #57
The W4-1798S ?
Old 6th November 2012, 07:13 PM   #58
If I were to put one Alpair cabinet on its side (center) and two upright (LR) would that affect tonality or coherence across the front stage at all? What about baffle step? Originally, I was thinking of three short boxes, all the same to fit under the projection screen as the 'ideal' front stage matched sound, but I'm weakening on going the usual way instead (different LR and center cabinets). What say you?
Old 6th November 2012, 07:40 PM   #59
The W4-1798S ?
3" is better but of course you have to combine it with midbass
Old 6th November 2012, 07:44 PM   #60
I assume you mean the W3-1797S.
Any full ranger in the Tang Band flat cones better than W4-1798S? Keep in mind I only need them down to 100 Hz. I have a decent subwoofer already.
Anyone (maybe you?) compared them with the Alpair?
Best size for full-range driver? sprinter Full Range 59 28th February 2011 04:56 AM
full range ht setup help kazoo Full Range 18 17th November 2007 03:19 AM
full range low cost and small size driver availability in Mumbai cutesound Multi-Way 1 14th October 2006 03:16 PM
full range speaker for HT Jazzz Full Range 13 8th September 2006 08:27 PM
Driver Suggestions for DIY Full Range Monitor?? masterhifi Full Range 0 23rd September 2004 08:05 AM
Copyright 1999-2017 diyAudio
