#21 | |
The HDS is also better than the Seas 27TDFC in terms of subjective detail and quickness. There seems to be more treble extension. It's a closer comparison as the material and frequency response is more similar between these two than the HDS vs Dayton. Some of the difference is that the HDS is 25mm diameter so it is smaller than the other tweeters. The datasheet lists it as having lighter moving mass. Whatever the case, it just sounds great. |
#22 |
Hi, Zaph|Audio , rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#23 |
Thanks for the comparison. How low can these tweeters be crossed with a 2nd order crossover, before distortion starts.
#24 |
Speaking of high efficiency designs for home use, I wonder what is the reason for the rising popularity of the HE designs from Zu audio and Tekton ?? Did anybody listen to any of their HE designs.
I have not heard their speakers but have experimented with the same drivers they have used: Eminence BP102, 208 EZ, Fostex FE series etc. |
#25 |
Sreten's link to Zaphaudio will give you an idea. It depends on how much power you need. You can even use it without a crossover as it naturally starts rolling off at 2kHz.
#26 |
#27 |
#28 |
Using any tweeter without any high pass filter at all is a complete no-no. Distortion will be very poor, the 12dB/octave roll-off = constant excursion per octave, so it it will excursion limit due to bass, meanwhile producing buckets of unnecessary intermodulation distortion, and is almost certain to fry for any decent overall power level applied, a complete non-starter. Flea power you might get away with it, but still pretty pointless. A series capacitor is the minimum for any sensible design. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 30th October 2012 at 09:15 PM. |
#29 |
All I will say is that I've done distortion measurements on the HDS tweeter and it worked fine even without a filter. In fact, distortion was very low. Now, at higher levels, sreten may be right. Who knows. I don't like to waste my time theorycrafting either way. I used a filter and crossed at 2.5 kHz in the final speaker. But the peace of mind I get from doing distortion measurements, that's something.
#30 | |
Not at 100W programme with mild clipping, or any sort of intermodulation distortion testing. Your the person wasting peoples time saying something works when it doesn't and wasting peoples time with "theorycrafting ". rgds, sreten.
| Active high dynamics/SPL & high performance loudspeaker system for my living room…! | Robert GS | Multi-Way | 77 | 30th December 2012 10:39 AM |
| Power supply:Universal AC input/ Full range,High Efficiency, and High reliability | hang | Vendor's Bazaar | 12 | 24th July 2009 03:46 AM |
| Low wattage, high efficiency, high quality? | Nordic | Multi-Way | 5 | 4th September 2005 11:12 PM |
| High Efficiency, High Power Handling? | Bogie | Multi-Way | 3 | 2nd July 2005 05:49 AM |
| Suggestions for high efficiency high SPL kit/design | Kanga | Multi-Way | 50 | 23rd May 2003 12:52 AM |
