High efficiency = Increased dynamics ?!
Old 27th October 2012, 08:32 PM   #11
R.I.P.
Originally Posted by Boscoe View Post
Not if they have different efficiency's...
Your understanding of efficiency for drivers is completely wrong. There is no magic.
rgds, sreten.
Old 27th October 2012, 09:55 PM   #12
Boscoe is offline Boscoe  United Kingdom
Sorry yes forgive me...
Audio projects and more: gswdh.co.uk
Old 28th October 2012, 04:22 AM   #13
soundaatma is offline soundaatma  United States
How do you feel about Troels Gravesen's site High Efficiency Speakers
where he praises high efficiency speakers eloquently despite having designed plenty of low-medium efficiency speakers in the past. He certainly seems to have a lot of experience in speaker building.
Old 29th October 2012, 01:13 AM   #14
I would say they sound better due to lower distortion because they don't have to work as hard and do less cone movement which kills little FRs.
You are in a way correct Boscoe, about lower distortion. But for a different reason as explained here ULTIMATE
It is more about the amplifier requirements to clearly reproduce a specific dynamic range during transients. For example a 120 W amp used with a 85dB/W speaker can cleanly reproduce a transient of 106 dB before clipping. OTOH a 95dB/W speaker can reproduce a transient of 116dB before clipping.
So the distortion from an amplifier is minimised by using high efficiency speakers resulting in a more "dynamic " sound as the dynamic range of the system as a whole is increased. So for a low efficiency speaker the amplifier distortion will likely become a limiting factor even before the speaker has run out of excursion.
This would also have benefits on background noise from the amplifier providing a quieter noise base to start with. In the above combination, to reproduce 106dB the HE speaker would require the amp to be delivering 16W that can be done at a lower noise than the 120W which will be needed if using the 85dB/W speaker.
Old 29th October 2012, 03:47 PM   #15
horst303 is offline horst303  Australia
As I see this, there are two aspects to high sensitivity speakers sounding better than low sensitivity speakers, one is the sensitivity that comes from the overall electro mechanical design, so comparing a 4" driver with 85dB/W/m to a 4" driver with 88dB/W/m, to produce the same SPL they have to sweep the same volume, because that be the physics, but the 4" driver with the greater sensitivity is less demanding of the amplifier, which I believe has sonic benefits, even before the amp goes into clipping.
The second aspect is the sensitivity that comes from increasing cone size, the 4" 88dB/W/m speaker will have to travel a lot more in and out than say a 8" 88db/W/m driver for the same SPL, which means that, if you can accept that distortion increases non linearly the further the cone moves away from the zero position, it will result in better sound. If you want to call that greater dynamics or lower distortion is neither here or there I think.
This then beautifully explains why you can buy 8 4" drivers from parts express for $10, team them with 20 cent tweeters and produce a speaker of astounding ability, or why horn speakers which introduce so many other problems sound so amazing, it's all about sensitivity.
And it also explains the cult of the 3 watt valve amplifier, it's not the amp, it the fact that they have to be used with high efficiency speakers which just naturally possess lower distortion.
Old 29th October 2012, 10:48 PM   #16
Hmmm...well said. I used to think tube based amps have some "special' thing called "fluidity"...no idea why. I do agree that tube amps do have prominent low mid range presence or "warmth" that I believe can also be added in with an inexpensive equalizer if desirable.
Old 29th October 2012, 10:57 PM   #17
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
You can't simulate a tube amp sound that way. You would have to increase the output impedance and add monotonically decreasing harmonics digitally. The equalization would be based on the impedance curve of the speakers. Then there are the really good tube amps that are very quick and detailed, fast transient attacks and airy treble. Those would be harder to simulate than the warm tubey stuff (which I do not like).
The tube amps do sound more dynamic, due to the rising response curve.
Anyway, the assumption you seem to be making is that lower efficiency speakers do not sound dynamic. This is not true. You have simply not heard any good ones. The 4" drivers you list in your post are simply not good speakers when run by themselves. Not even close. Listen to a Linkwitz Orion or a Peerless HDS based system, then decide.
Old 29th October 2012, 11:07 PM   #18
R.I.P.
High sensitivity speakers generally have less distortion issues and less
thermal compression issues. They also tend to be more coloured.
And unfortunately physics intervenes when it come to the bass end,
they need to be big to produce decent bass extension and levels.
The optimum compromises are different for different people and
can depend a lot on the amplification chosen if it is low power,
and intelligent compromises need to made for low power.
e.g. something like :
Speaker kit 3 : Peerless SKO204 + DT105 + crossovers ! | eBay
In bix boxes like :
Tuned low, around 33Hz and used near walls / corners will make a
surprising fist of lower powered amplifiers, size and efficiency matters.
rgds, sreten.
Old 29th October 2012, 11:34 PM   #19
rgds, sreten.
Completely agree with you Sreten about the need for bigger boxes for the bass end for HE speakers. But not so, if active amplification (+/- equalisation) with low efficiency drivers is employed for the bass only region, allowing smaller boxes. Dynamic and unclipped reproduction is very essential in the mid-high frequencies where the ear is most sensitive, moreso than the low bass region. Hence the proposed preference of HE 4" full range drivers than the low efficiency ones.
Just a thought
Old 29th October 2012, 11:45 PM   #20
Fully agree with you...that is why the listed 4" drivers are all to be used with woofer support and not to be run by themselves.
I have the 8" Seas Mag woofer of the Orion and compared it to the Fostex 208 sigma for OB designs. Have not tried the tweeters you mention though. Could you please tell me what is so special about the Peerless HDS tweeter compared to the similar but lower priced Dayton Audio RS28A-4 . Thanks.
High efficiency = Increased dynamics ?!Hide this!Advertise here!
Active high dynamics/SPL & high performance loudspeaker system for my living room…! Robert GS Multi-Way 84 19th January 2017 10:34 AM
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 04:46 AM
Low wattage, high efficiency, high quality? Nordic Multi-Way 5 5th September 2005 12:12 AM
High Efficiency, High Power Handling? Bogie Multi-Way 3 2nd July 2005 06:49 AM
Suggestions for high efficiency high SPL kit/design Kanga Multi-Way 50 23rd May 2003 01:52 AM
Copyright ©1999-2017 diyAudio
