multiple driver speaker
Old 3rd March 2013, 01:07 PM   #31
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Good news Turk.
planet10 needs your help:
Let's help Ruth and Dave
Old 3rd March 2013, 05:12 PM   #32
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Hey there Turk. You definitely didn't offend me! I've just been so busy it's crazy.
Good news on the bifrons; sounds like you ended up arranging them exactly as I have mine. In the end the only thing I really had to change about them was the hot mid-range resonances I was getting. I added a ring of putty around the whizzer cone (pressed right into the gap where the voice coil former is visible) as a terminator to damp transverse modes in the cones. This ended up having exactly the desired effect and also reduced fs a bit for better bass response. The only real drawback to this mod is a reduction in efficiency but they are still very efficient.
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 3rd March 2013, 05:58 PM   #33
turk 182 is offline turk 182  Canada
duo
busy is good i hope that along with the craziness there's cash!
i'm still running the original wiring scheme and drivers (other than the visaton's on the back)
and just a comparision of terms i'd be more apt to say that they have comb filtering happening in the upper mid's which colors them not resonances but i will have to try the putty thing to see.
i'll ask again what is your acoustic resistor for aperiodic tuning?
the next thing i am going to experiment with on these is to rewire them to obtain a more cohesive wave front(the original scheme places the "hot" drivers in series legs at co-incident points which doesn't help)
p.s. : i'm still trying to confirm a rumbling about a low frequency compensation circuit that was built into a companion (matching/intended) amp.
Old 19th September 2013, 10:52 AM   #34
i'm hoping a bump will revive this thread i'm still trying to get info on these and any and all other products by BEAG or stereo equipment bearing the JANUS logo
anyone...
Old 15th December 2013, 01:08 PM   #35
the Bifrons hox-05 is appropriately named!
after listening to these speakers for a couple of months i still couldn't quite figure out what it was about them that made me stop and focus so intently on them.
i've now realized it's the comb filtering!
after a few quick checks with the RTA there's huge notch's in the mid range from aprox. 800 hz up to about 3khz that occur in the 17 to 48 degree region not to mention the 300 hz broad peak that i'm pretty sure is the result of too small a box ,being that it's intended as a sealed enclosure.
after some experimentation (as in running half the box and aperiodic and reflex tuning it; even trying a six inch sub driver in dipole) i'm reasonably certain that without changing the box geometry and implementing the right combination of crossover/eq they are a masterful example of how not to build a speaker!
Old 15th December 2013, 06:31 PM   #36
Duo's Avatar
They do have some funny frequency response effects and a nasty peak in response for sure. I improved mine dramatically by adding mass to the cones of the drivers (I may have mentioned that earlier in this thread).
After adding mass to the drivers I found an aperiodic or sealed enclosure ended up being the best thing. You still get the comb effects and the bass response lacks but regardless of empirical measurements there was a quality about the Bifrons I could never get past; most of my friends had the same impression of them.
Old 15th December 2013, 06:56 PM   #37
sorry duo you can add whatever you want to the drivers or tune the box how you like; it's a bad design which would make even the best drivers you can find sound like a--!
your right i couldn't get passed the quality of comb filtering !
p.s. the drivers individually in a 1.5 liter enclosure sound awesome!
Old 15th December 2013, 07:59 PM   #38
Duo's Avatar
Say what you like; I love the sound of these speakers, as do many others.
Old 15th December 2013, 08:13 PM   #39
anybody else own these in their stock configuration like to chime in?
Old 15th December 2013, 08:22 PM   #40
Duo's Avatar
I'll agree they sucked in their stock state. And even with modifications they sound weird and can be hard to get used to. But after you get past that there's some reason I just can't stop enjoying them.
multiple driver speakerHide this!Advertise here!
Multiple drivers vs. single driver sub AJ34 Subwoofers 46 16th November 2012 03:49 PM
Multiple driver connection, impedance Dr_EM Subwoofers 5 3rd June 2009 09:44 PM
Multiple driver MMT calculation question JohnIsBaffled Multi-Way 3 4th August 2008 01:31 PM
multiple driver HT sub ..how to design ? JinMTVT Subwoofers 78 4th September 2007 04:56 AM
Multiple driver sensitivity gain? woody Multi-Way 3 12th February 2004 03:24 PM
