Which 8 inch driver to use for the low end?
Old 26th October 2012, 03:48 AM   #1
jdm91 is offline jdm91  United States
Default Which 8 inch driver to use for the low end?
Good Evening everyone ,
Me and my friend was wondering about a few drivers that are fullrange 8 inch woofers from fostex? The model numbers from fostex are;
1. FE 208ez
2. FF 225wk
3. Fw 208n
I going to be building speakers for a friend and this is what was asked? Does anyone have any ideas or helpful hints? Money wise worth it or not worth it? He is looking for a 8 inch drivers that can play fullrange and these are the ones I have seen. Jeff
Old 26th October 2012, 04:33 AM   #2
Melo theory is offline Melo theory  United States
Melo theory's Avatar
Well, what kind of enclosure would you like to build?
The first one is definitely best in a BLH (back loaded horn)
Number 2 and 3 are more flexible in regards to enclosures.
I LIKE YOU
Old 26th October 2012, 04:40 AM   #3
jonparkhurst is offline jonparkhurst  United States
Evening. I still am young enough that I have some top end left. The fostex 225 will not satisfy you in the top end no matter the enclosure. You will need a tweeter. FYI. I can not speak to the others but in the right box the tang band 1772 and 1808 work nice, but price is higher. What about a mark audio or the Dayton audio 8 ????
Old 26th October 2012, 04:44 AM   #4
Yeah, also the Fw208n isn't a full range.
I LIKE YOU
Old 26th October 2012, 08:34 PM   #5
Enclosure kind? Well I would love a rear ported design if I can get away with it. Jeff
Old 26th October 2012, 08:35 PM   #6
Yes I was plaining on useing a super tweeter with the above 8 inch fullrange drivers. I am aware they don't go as high as the smaller fullrange drivers. Also I am looking for a 8 inch driver that can go as high as it will let me. Tang band I have not looked into and the dayton looks nice but, does not go high enough for me. Jeff
Old 26th October 2012, 08:37 PM   #7
Ya I must have miss read the response graph. Thanks for pointing that out. Jeff
Old 26th October 2012, 09:08 PM   #8
well....here ya go bud
http://www.brinesacoustics.com/Pages/B18-F225/Main.html
I LIKE YOU
Old 26th October 2012, 10:09 PM   #9
tvrgeek is offline tvrgeek  United States
Totally agree. It seems like a "fullrange" needs a sub and a helper tweeter. I may be old, but I call that a three way.
Old 26th October 2012, 10:28 PM   #10
I agree with this if the full range is too large.
What I like is a 3" full range with helper woofers.
That way you can cross them really low and avoid a lot of problems such as time alignment, polar response, phase anomalies and group delay around the crossover, (you can use shallower slopes) just to name a few.
Most 3" drivers will behave up top and will only get wonky above 10kHz off axis.
You can cross most 3" FR at 500Hz 1st or 2nd order.
I call this configuration FRA (full range assisted)
Instead of FAST (fullrange and subwoofer technology)
The later is crossed lower and should be used with subwoofers...as per the acronym.
I got this idea from sreten. (the FRA acronym)
I LIKE YOU
Which 8 inch driver to use for the low end?Hide this!Advertise here!
Does the intrinsic low-end roll-off of a mid driver change the phase error? andyr Analog Line Level 7 15th December 2010 07:27 PM
four inch driver with good efficiency and low Rms/high Qms? twest820 Multi-Way 23 18th August 2010 04:55 AM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 04:02 PM
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 04:32 PM
high end version of low end phono stage dsavitsk Solid State 20 2nd September 2005 12:51 AM
Copyright ©1999-2017 diyAudio
