Old 23rd October 2012, 01:05 AM   #1
Default Impedance Correction in Single Drivers
Hello friends. In the world of Multi Drivers and of Crossovers, the Impedance Correction Circuitery called "Zobels" is of importance to flaten the overall impedance of driver(s).
my question is;
How important or not, is the same circuit in a Single Driver situation. Would having one take away from sound quality?
Thanking you in advance,
Vilic
Old 23rd October 2012, 01:09 AM   #2
frugal-phile(tm)
planet10's Avatar
It depends on your amplifier.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd October 2012, 01:56 AM   #3
Bob Brines's Avatar
If you have a hi-Z amp or a large BSC filter, you can use a series resistor and cap to tailor the high end frequency response. But it is not a zobel per se because you are adjusting for the FR shape, not the impedance shape.
Bob
Old 23rd October 2012, 02:19 AM   #4
I have found that you can get a nice flat impedance curve on a fullrange with a zobel, at the expense of some top end roll off (not usually a good thing). If your driver is really HOT on top, this may help.
Larry
Old 24th October 2012, 01:02 AM   #5
Hello again and thank you very much for replying. The story is that I want to build a small TL with a 2" Tang Band driver. (W2-1803S) I do not want to add any Xover component if I can. But, if I have to say add just a cap to cutoff the low end (to protect the driver in higher levels of volume), how much of sound quality loss (i.e. staging, transition...) I should be expecting, using a regular transistor amp?
Thanks again,
Vilic
SPDIF impedance correction Koenjer Digital Source 44 23rd January 2012 09:39 AM
Impedance correction for old Fe103 (zobel) TKsys Full Range 2 20th March 2007 06:09 PM
How much do you focus on impedance correction? mr_push_pull Multi-Way 12 8th October 2004 02:22 AM
Impedance correction Ralph Multi-Way 2 15th August 2003 09:25 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
