Here is a photo of my latest speaker project using the Merrill DCA5.5 in the TriTrix cabinet from Parts Express. I was trying to design a new cabinet when I ran across the dimensions of the TriTrix, and discovered the box dimensions were a great fit for the DCA5.5 Thiel characteristics. A local cabinet shop had some leftover bamboo veneer from another job, so I got a great looking set of cabinets for my DCA5.5's. As for the sound, they are AMAZING! The drivers don't even have 10 hours on them and they already sound sweet. I can't wait till the drivers are fully broken in.
http://imageshack.us/a/img833/5893/t...rilldriver.jpg Last edited by MrKTrout; 2nd November 2012 at 05:38 AM. |
#2 |
MrKTrout,
Hello. Can you give me the plan of your cabinet. Thank you. Best regards. Philharmonie |
#3 |
I was so much older then, I'm younger than that now. |
#4 |
Hello Fastbike1,
Partsexpress the tritix are for MTM speakers to 2, 5 channels but not for a transmission line. Thank you. Best. Avec tous mes remerciements de France. |
#5 |
Hi Philarmonie,
Maybe this design works : model images of dca4 t-line enclosure It's T line.. Regards. Phil. |
#6 |
pretty
#7 |
Philfr,
The DCA4 has completely different characteristics of the DCA5.5. If someone has plans for DCA5.5 I'm interested. Thank you, the French. Best. |
#8 |
The OP used the Tritrix enclosure, but with Merrill driver instead of the twin midbass & tweeter. See here for the box plan: http://www.parts-express.com/project...aker-projects/
#9 |
I think the only way is to create your own design. With high Qts, a straight TL should work. To modelize the speaker, you can use MJ King Mathcad sheet : Quarter Wavelength Loudspeaker Design @+ Phil. |
#10 |
Hi Philfr,
It is ok a high Qt with a TL line is appropriate. I am a pensioner who is not very strong on the internet and I speak English very poorly. This will not be easy. Dominique Petoin has already given me a plan. But I would like a smaller speaker because I did not need to descend in very low frequency. The addition of a subwoofer will be later. I am looking for a plan inspired by the prototype of Ronald THACKERAY Audio Caroline. Thank. Best. |
| full range in an existing small cabinet | mda1 | Full Range | 33 | 11th September 2012 05:41 PM |
| Spherical Cabinet vs. ordinary Cuboid Cabinet for full range Speakers | tiefbassuebertr | Full Range | 1 | 10th January 2012 04:49 PM |
| Easiest cabinet design for full range driver | terpkev | Construction Tips | 23 | 31st July 2011 08:16 PM |
| Merrill DCM5.5 Full Range Drivers For Sale | Doug R | Swap Meet | 3 | 20th October 2010 11:01 PM |
| Full range and/or High Efficiency possible in small cabinet? | Seraph | Full Range | 29 | 19th June 2007 01:13 AM |
