#21 |
well, my choice is made, I'm goinh with the alpair 7
now, what enclosure should I build. I want a bookshelve speaker that can sit on my stereo subs any recommendation? |
#22 |
a bookshelf speaker that sits on the subs? I can't picture that... are the subs quite tall?
#23 |
lol
#24 |
#25 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#26 |
I just ordered the 7.3
so excited! thanks everyone, they better sound good now ![]() men planet, does looks good! are those your favorite bookshelves enclosure for the alpair 7? how low do they go? Last edited by murphythecat8; 24th October 2012 at 12:21 AM. |
#27 |
frugal-phile(tm)
Those are EL70eN (wide trapezoids). The similar enclosure for A7 is a bit smaller, and it would be my favourite for the A7.3 if used with a woofT. There are 3 widths of trapzoid Mar-Ken for the A7.
dave
#28 |
I finally decided against the 7's, I will get the 12's!
#29 |
Am I too late?
How high up will your stereo subs go? If they'll hit 300Hz nicely, you could take the crossover much higher than would be conventional, allowing you to give the FR driver an easier time (less distortion due to cone excursion etc). This would benefit all full-range drivers, but I'd expect moreso the A7.3 as its cone area is small, so must move more to keep up with the bigger drivers in terms of sheer output. If I am too late, don't worry - you'll have plenty of fun with the A12s. You could try taking the crossover higher up, but you probably won't hear much benefit until you're at really high SPLs. Chris |
#30 |
Mark (I think) did mention that the new A12 is best suited to low watt tube amps.
If you are thinking the A12 is bigger so must move more air you may be disappointed. Size really aint everything, especially when it comes to full ranges. If you want 3d imaging = A7 Bass = A10 |
| Alpair 10 -12 | Mike in NJ | Markaudio | 7 | 28th March 2012 03:31 PM |
| Alpair 12 vs Alpair 10.2 and a little Fostex 166 | germpod | Full Range | 4 | 28th January 2011 03:19 PM |
| Alpair 10 more forgiving than Alpair 7 & 12 | tripathdude | Full Range | 3 | 6th November 2010 06:14 AM |
| Alpair 10 vs Alpair 12 | buzzforb | Planet 10 hifi | 0 | 30th October 2010 06:56 PM |
| WTB: Alpair 10 or 12 | ra7 | Swap Meet | 3 | 10th September 2010 10:58 PM |
