A fast way to build FAST
Old 14th October 2012, 06:02 AM   #1
solhaga is offline solhaga  Sweden
Default Building FAST, did some CBTs - ended up in FAs
From an attempt to build a line source out of 2" fullranges, well almost, I got a couple speakers left over:
Yes, it is Jordan/EAD E60.
Edit:
As it turned out, it ended up in CBTs using the same building practice.
Edit one more time:
Dramatic turn of events; now it´s FAs using the same building practice.
Last edited by solhaga; 28th November 2012 at 08:40 PM. Reason: More correct heading
Old 14th October 2012, 06:11 AM   #2
madtecchy is offline madtecchy  England
And????????
Old 14th October 2012, 06:13 AM   #3
So what to do? I wanted a quick evaluation of the speakers as they are meant to be used.
Had some aluminium profiles laying around:
Cut one of them in four, thus making them 25 cm each:
Old 14th October 2012, 06:16 AM   #4
I also had some 13 cm MDF board scrap, the leftovers from making the baffles to my dipole bass:
Old 14th October 2012, 06:17 AM   #5
So are you selling some of these drivers or what ??
Old 14th October 2012, 06:17 AM   #6
DUG is offline DUG  Canada
And????????
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 14th October 2012, 06:23 AM   #7
them drivers are expensive . 32 of them in the piccy.. now if i was going to spend that much on drivers i would make sure i knew exactly i was doing first not buy them and then learn lol..
Old 14th October 2012, 06:23 AM   #8
With 13 cm deepth, 9 cm width and 25 cm height, it ended up with a volume of 3 liters.
And that just about two times the Vas of one element.
With all the pieces cut out:
Let´s start assembling.
Old 14th October 2012, 06:23 AM   #9
Originally Posted by DUG View Post
And????????
Hi dug can i help you ??
Old 14th October 2012, 06:32 AM   #10
Sides:
Back and first front piece:
Bottom (and top):
Any mismatch that will result in leakage is covered with silicone rubber, on the inside for front and top and from the outside for the bottom.
To make the bottom easily detachable adhesive tape can be used instead.
A fast way to build FASTHide this!Advertise here!
FAST build with Alpair 7.3 and Seas L26ROY and Hypex AS2.100 Swifty Full Range 40 28th October 2015 01:57 PM
FAST Build: Alpair 7.3 - Seas L26ROY Swifty Full Range 28 26th June 2012 07:27 AM
Fast build - DubStep certified on a budget! Blindsite Multi-Way 2 8th May 2011 02:33 PM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
I need a really simle and fast amp to build trespasser_guy Solid State 12 15th August 2002 08:22 PM
Copyright ©1999-2017 diyAudio
