A fast way to build FAST
Old 1st December 2012, 09:43 AM   #31
solhaga is offline solhaga  Sweden
Originally Posted by solhaga View Post
I was sitting in the third row to the left right .
Sadly, I couldn´t see him pluckin´his guitar from that angle.
Old 4th December 2012, 11:00 AM   #32
Default Got focused
So I managed to build a couple of FAs:
From this angle nothing seems to have changed, but instead of CBTs it is now concave focused arrays.
Measurement from sweet spot:
Red curve is somewhat 20 dB higher in reality, the elements are couple 4 and 4 in parallell and then in series.
Blue curve with resistors (120 ohm was what I could get on a Sunday afternoon) in series with each element.
All the elements plus their resistor is then coupled in parallell.
I will mount 56 ohm instead of the 120 when I get them.
The humps at 150 Hz, 650 Hz and 1500 Hz are candidates for some EQ:ing;
XO will probably be at 250 Hz so I don't bother with the one at 140 Hz.
So any comments on the two curves?
Old 9th December 2012, 02:10 AM   #33
Illusus is offline Illusus  Canada
Illusus's Avatar
Surely, you had to have had listened to music through both CBT and FA set ups. Which did you enjoy more and why?
Fighting the program since 1976.
Old 9th December 2012, 12:34 PM   #34
It was very hard to get the CBTs integrated with the woofers, it was just a bass blur around the XO. Above the XO, the sound wasn't great either.
So having multiple identical sound information arriving with different timing to your sweet spot isn't a great idea; I don't understand why one should want to have CBTs in a home environment.
The FA setup, however, is giving my dipole ribbons a real match. Waving my head around didn't produce any awkwardness either. So perhaps the sweet spot isn´t that small.
I just finished replacing the 120 ohm series resistors with 56 ohm and have also done some paint job and haven't had the time yet to really listen to the FAs.
I haven't done serious EQ-ing either, so I have to come back with some feedback.
Old 15th December 2012, 10:45 AM   #35
Painted the FAs black to match my subs:
Click the image to open in full size. Click the image to open in full size.
Finally did the EQ:ing. Looking at the blue curve in the post above, I never understood the dip around 1 kHz. Does anyone have a teory?
Anyway, everything is there: soundstage, lows and highs, you name it.
This will be my setup for a while, at least over the holidays
Next project will be to make five HT satellites out the 18 E60s I got left.
I'll be doing the fast way, so they might turn up in this thread as well.
Old 15th December 2012, 11:29 AM   #36
xrk971 is offline xrk971  United States
xrk971's Avatar
Nice job! Looks fantastic. Can this be done much cheaper a la Melotheory with vifa tc9fd's? I don't dare ask what all those Jordans cost...
Old 15th December 2012, 11:32 AM   #37
Melo Theory actually inspired me in the first place.
Mine's got an open back though, that is they are dipoles.
A fast way to build FASTHide this!Advertise here!
FAST build with Alpair 7.3 and Seas L26ROY and Hypex AS2.100 Swifty Full Range 40 28th October 2015 02:57 PM
FAST Build: Alpair 7.3 - Seas L26ROY Swifty Full Range 28 26th June 2012 08:27 AM
Fast build - DubStep certified on a budget! Blindsite Multi-Way 2 8th May 2011 03:33 PM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 10:00 PM
I need a really simle and fast amp to build trespasser_guy Solid State 12 15th August 2002 09:22 PM
