A fast way to build FAST A fast way to build FAST - Page 3 - diyAudio
Old 18th October 2012, 03:36 PM   #21
madtecchy is offline madtecchy  England
i have a pair of bipoles i listen to daily and nightly to tell the truth whenever i can .. they fill my room with not much power needed . Now i must remember to have a listen to some omnipole speakers..
kind regards Mark
Old 20th November 2012, 09:30 PM   #22
solhaga is offline solhaga  Sweden
Default A fast way to build a CBT
I couldn´t get my mind off of building a line array of the E60´s.
With the experience of building the design above, I realized that it would be easy to build CBTs:
I´m trying burlap to get rid of some of the hf intermodulation.
Kanthal thread supplied the shading from 0 to 32 ohms.
I then got this frequency response in sweet spot:
A curve fairly easy to adjust with Frequency Allocator.
Old 21st November 2012, 05:38 AM   #23
So the line array is acting as a line source from 500 Hz, hence the 6 dB rise.
Hf cancellation kicks in at 3 kHz, despite the CBT and burlap, with a 6 dB/octave slope.
So the eq is bringing down 500 Hz to 3 kHz 6 dBs and then there´s a 6 dB/octave rise from 5 kHz.
XO is set to 250 Hz.
Any suggestions for another diffractor material than burlap?
Old 21st November 2012, 06:50 PM   #24
So this is my new setup:
Old 21st November 2012, 06:57 PM   #25
silverhairbp is offline silverhairbp  United States
Are you planning to add some drivers for bass or just use those small black drivers on each side and slightly behind the array?
Old 21st November 2012, 08:52 PM   #26
No plans for adding more bass drivers than the three aside TD15H that I have in the OB bass baffles.
Old 28th November 2012, 08:35 PM   #27
Default FAST goes FA
I went to a concert the other night; Zappa plays Zappa. It was awesome, but I also focused on the PA. Up in the ceiling there were some CBTs...
Of course, that makes perfectly sense, as I was sitting in the third row to the left right in front of Sheila, I was subjected to the shaded bottom J of the CBTs. People far back were given the unshaded SPL from the CBTs.
So why do I have them in my listening room, sitting in the same sweet spot?
And why do I think that having multiple, all different in time, soundwaves will sound good?
Thanks to norman bates and Melo Theory and their patient answers to my questions in their threads, I'm now convinced that focused arrays(FA) is the way to go. Again, thank you guys!
I´ll be re-using all the components I have so far. Well except for the burlap and the Kanthal wire of course. The contraption will be almost the same, this time the curve will be concave and uniform.
Old 30th November 2012, 10:26 PM   #28
Now I´m focusing on this:
18 or 20 elements in an open baffle. Focal point is at 280 cm.
Sweet spot at 250 cm, sharp!
Old 1st December 2012, 01:49 AM   #29
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
A concert i'd really like to see. Frank said Dwezil was a better guitar player than he was.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st December 2012, 02:05 AM   #30
doorman is offline doorman  Canada
doorman's Avatar
dave
Might have been the proud poppa syndrome, but D. Zappa is no slouch.
High praise indeed!
Don
A fast way to build FASTHide this!Advertise here!
FAST build with Alpair 7.3 and Seas L26ROY and Hypex AS2.100 Swifty Full Range 40 28th October 2015 01:57 PM
FAST Build: Alpair 7.3 - Seas L26ROY Swifty Full Range 28 26th June 2012 07:27 AM
Fast build - DubStep certified on a budget! Blindsite Multi-Way 2 8th May 2011 02:33 PM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
I need a really simle and fast amp to build trespasser_guy Solid State 12 15th August 2002 08:22 PM
Copyright ©1999-2017 diyAudio
