#41 |
The first Karlson 12 aka "Karlsonette" which made its debut in fall of 1954, second K12 whose plan was published in the July 1954 issue of Popular Mechanics, and some guesstimate of the 3rd version of the 1960's are all in Greg B's folder along with SK8, XK8, a tested 28" tall slim K-coupler and more stuff - I have run FE206EN in SK8 and K12 plus should load it in my XK8 which is a high aspect Karlson-coupler. K12 kept its outside dimensions along the years but had subtle changes with baffle angle, and venting http://picasaweb.google./comgregmuon/STUPIDHIFITRICKS#
#42 |
Your link is off a little
Picasa Web Albums - greg muon - STUPID HIFI T... Had to move the .com back
Aggressively Passive |
#43 |
One box that hasn't been mentioned yet is Onur Illkorur's Singular -basically it's a folded constant cross section QW pipe with an internal Helmholtz resonator, presumably tuned to the 3rd or 5th harmonic (I haven't calculated it).
Not exactly a compact cabinet for what sounds a v. small room, but shoved back against a wall I suspect it will produce some respectable LF energy in that space. |
#44 |
has the intended venue changed from the original 100 ft^2 described in first post?
I have trouble imagining any of the larger enclosures that would no doubt work for the 206 fitting comfortably in that space and leaving room for even a single listener and bar stool OK, I joke a bit - but the room is small, and might well be better served by a smaller driver
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#45 |
Im rethinking it.....I have some of the Vifa 3.5 coaxs but would need a subwoofer.....
#46 |
Assuming you don't want large boxes, you'd need a sub with the 206, so no difference there.
#47 | |
Bill
The difference between theory and practice is that in theory there is no difference between theory and practice, but in practice there is. |
#48 | |
Preferably, i recommend to build something with smaller drivers dfor that room. Markaudio comes to mind. but I believe that the 206ens are already bought, in that case Horst's compact Trumpet-sat which I linked above seems like a good way put when combined with an active sub. |
#49 |
I'd tend to agree, although I suspect I'm another one who would be more inclined to run the 206s sealed, albeit with woofers rather than subs, crossing at or just above the mass-corner.
#50 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Enclosure ideas | Skysoldier | Tubes / Valves | 7 | 1st September 2012 03:04 PM |
| FE206ES-R in short enclosure | DavidLewis2 | Full Range | 56 | 10th October 2007 03:03 PM |
| Looking for ideas for bracing a lightweight enclosure | owdi | Subwoofers | 3 | 15th September 2006 04:12 PM |
| Help with enclosure ideas | path914 | Multi-Way | 4 | 15th February 2005 06:56 AM |
| Enclosure design ideas??? | Milzie | Multi-Way | 9 | 27th November 2002 04:43 PM |
