effecient 2-3" element?
Old 4th October 2012, 07:04 PM   #11
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
thanks RJ, I didnt know that. But are the CDs that exhibit -40db THD at 400hz? What you say is quite correct that there is plenty of 'throw away' SPL using compression drivers, but I think i would be concerned about the multiple resonance many CD have, particularly as low as 400hz. I havent tried that approach, so I dont wish to discourage others. My impression was the OP wanted a cone driver, though I may be wrong.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 4th October 2012, 07:25 PM   #12
rjbond3rd is offline rjbond3rd
Hi mondogenerator, you are absolutely right, he is seeking a cone but a compression driver sounds so much better for demanding music with impact and dynamics (e.g., orchestral, movie soundtracks) (at least to me).
I'm not knowledgeable about the implications of using one on a constant-directivity waveguide except that the (various) Cornscala designs are often built that way (though many cross them higher).
I guess the "low crossers" are most typically the Klipschorn and LaScala modifiers, who have identified a handful of compression drivers that can handle it. I have been happy with the Klipsch K55V on a Fc 310Hz "Elliptrac 400", which can also handle a few (better-sounding) 2" drivers. Something similar is the "Volti Vittora" which looks like a LaScala but sounds much better (to me).
Old 4th October 2012, 07:55 PM   #13
I can see the appeal of such waveguides, i merely havent made that 'jump'. What interests me is the loading of such 2inch drivers like the TBs, but getting the bandpass wide enough in hornresp is almost impossible for me. WAY off topic, so ill be quiet For a cone driver of 2 inches the W2 800 is usefully sensitive, and sounds clean to my ears, and i padded them down 6 or 8 ohms, maybe 6dB. 1st order HP w 47uF, not good. I ended up with a 2nd order at around 500hz. Stretched a bit lower than that, maybe JUST 400hz but i think i simmed it 3rd order to protect the driver. Max spl came out at ~95db. Knock 3dB off for a margin. Maybe a 2 incher isnt man enough for the job? Waveguiding here is a great advantage though. Personally, i would love to adapt RJ's 310hz ones for my TB W2s
Old 5th October 2012, 03:57 PM   #14
Electron is offline Electron  Finland
TangBand W3-1285 and W2-800 looks promising. The other two have issue in the top octave.
W3-1285 looks actually very good because the top octave seems to be rising. Wave guide is not boosting the top octave at all and the boost max is somewhere 400-1k. This means that power handling should not be an issue.
I have no experience how compression drivers work with waveguides. Wave guides are any way far more flat than horns and therefore not loading element that much.
Is 2" compression driver behaving alone without horn as 2" flat cone?
Old 6th October 2012, 02:53 PM   #15
Yes the TB drivers i mention both have a roughly 12dB rise in the uppermost octave which may be useful in extending the HF gain in a CD device where the HF output gain starts falling. I got these drivers for widerange tweeter essentially, i also have visatons 2 inch frs5x which are also very good, but perhaps slightly less sensitive. Very cheap and great value.
effecient 2-3" element?Hide this!Advertise here!
Using 12" guitar element as high efficiency midrange? Elias Multi-Way 56 28th April 2018 07:32 AM
looking for effecient 4" driver for FAST system Josephjcole Full Range 24 13th April 2011 12:50 PM
L as last filter element? rman Tubes / Valves 2 4th June 2008 02:31 AM
What is this circuit element? leadbelly Digital Source 14 1st March 2005 03:48 PM
