Old 9th October 2012, 07:24 PM   #21
RWB is offline RWB  United Kingdom
I still want a set of speakers that are really nice for general listening, and these are what they'll be used for 95% of the time. I just also want have it so friend can mix through them for after parties etc. Not talking massive SPLs, for lounges and communal area in houses.
Maybe build up a 3 way system with subs, full range drivers later along down the line add some tweeters?
Old 9th October 2012, 07:45 PM   #22
sippy is offline sippy  United Kingdom
Why not add a sub or two to what you already have?
Then build a full range for own use and hide them away when you're all smashed out of your skulls.
I once went to a party and the host was mixing through a pair of Tannoy D700's, sounded chuffing glorious they did, right up to the point when some 'cool' bint slopped her alke-pop over one of them. She had to sell her car to get the speaker repaired and was struck off the 'After Party' list.
One respected member on this forum said this of the 12lta:
The LTA is a wonderful driver. Not pretty to look at, but used right it's a real sleeper.
The quoters name is Pano
Old 9th October 2012, 07:49 PM   #23
zman01 is offline zman01  Bangladesh
CHP-70.1 is a candidate as long as you are not turning the wick up too much. For some more money the EL-70 will deliver more bass and SPL. If you like brighter sound then you can consider CHR-70.3 among the budget MA drivers; If budget permits then Alpair 7. Please note that the metal drivers, specially Alp 7 will have better treble dispersion vs paper.
Sippy, quite a story about the Tannoys... poor girl!
Old 9th October 2012, 08:48 PM   #24
tvrgeek is offline tvrgeek  United States
Originally Posted by zman01 View Post
tvrgeek,
Alpair 7.3 perhaps?
Alp 7.3 should get you down to 110-120... But would your subs go up there?
Would love to hear (more like read about) what you hear.
My Peerless XXLX are fine up to about 200, but you get terrible problems with localization if you are not using the subs as stands for the mains. Even 80 Hz, THX standard, at third order is not steep enough. I prefer about 60 Hz fourth. Neither of my Daytons go that high even though they are 10's.
Yes, the Mark Audio drivers are next on my list. 10P maybe with a crossover at 5K. Been through Fountec and Fostex. My FE85's do 110. Fine for computer speakers to do bings and bongs and a few on-line lectures. Useless for music even though they get up to about 10K.
I still have decent hearing to 18K. I know this when testing drivers. What do I hear? Music! Just switching to the metal dome from the silk dome Seas, which on measurement was only about 2 dB hotter at 18K, I heard a background thimble on a record I thought I knew completely. There is a LOT of music above 7K including a lot of the clues to localization. Imaging that is; height and depth. Unfortunately, between loud clubs, car stereo's and the worst problem, ear buds, we have a couple of generations who have severely damaged hearing so a midrange sounds fine to them. I have to believe those who favor full range do so because they have limited hearing and are most sensitive to the midrange. You can only evaluate what you hear. That's where their music pleasure resides.
Old 9th October 2012, 09:42 PM   #25
Originally Posted by planet10 View Post
I will disagree strongly. Synergy between amp & speakers is very important. The wrong amp can move a system from enjoyable to absolute trash.
dave
OK, there are a lot of really bad amps out there, some very expensive. Some of them are so bad they can't drive difficult loads. Bad amp, bad speaker. But, even my old Denon DRA-35 was better than a pair of Wilsons. Will a really good amp sound better? Yes. But better speakers would make a bigger difference than the best amp money can buy.
If a driver is so sensitive that amps make a big difference, I offer that it is a driver that should only be used in a pre-packaged system.
My Paradigm Studio 20's were slightly edgier with my Parasound than my Rotel. Why? The 20's had just too much distortion that the Rotel did not excite due to the VAS output compensation vs Miler. My fix was to build much better speakers. (Seas two ways) Now the Parasounds are cleaner with more detail. The Rotels still mask a bit of the high end detail. Audible, but not massive. Speaker differences were massive. The amp difference was about that between an electrolytic cap and a Mylar in the crossover. On that scale. I did try the unmodified Fostex drivers on a couple of amps. (6W tube, 60W MOSFET, 200W BJT) I could not hear a difference at all because the driver breakup and distortion was so much worse than the amps it made no difference. Your modified drivers are far better behaved, maybe an amp difference is audible. I only got a brief hear of them on a very nice old Luxman amp. It was not a problem.
Synergy I guess is a personal judgement. I don't find crossovers evil, but I find driver breakup in the usable range evil. Just as you work to control breakup issues, I work to manage the problems with crossover design. For my taste and skill, so far the crossover is winning.
For the subject of this thread, I still say a full range is harder to make a decent first project than a two way if the goal is a pair of speakers that will be used as main speakers. ( Not always the best choice) Pushing past the limits of a driver is far harder than building a two way with fairly fault tolerant parts.
An option is to start with a full range to see what the limitations are and then add a tweeter. Only with one of these really wide band drivers can one hear the difference between an LR4 @2K and an LR2 @ 5K one with the same drivers. No one said this was easy.
Old 10th October 2012, 12:55 AM   #26
Looking at how this project is directing, how are the Fostex full ranges compared to the Mark Audio drivers? Considering that I'll being using subs low end isn't much of an issue. Looking for something with plans available and no more than about £130 for the pair. (This is how much a pair of Alpair 7 1st gen cost).
Old 10th October 2012, 01:19 AM   #27
Just one opinion -- the Mark Audio's are delightfully robust in their sound, enough for home theater. They can often be "plug and play" as long as you get them in the right box. Drawbacks: the Alpair 7 (and other metal-coned models in this line) can have a teensy bit of "zing" which is great on cymbals, but can annoy the really sensitive listener (but only slightly). Also, they can sound a little "smooth" in the upper treble (to me) and a bit less gutsy and "real" than paper (to my ears).
Over-generalizing, the Fostex are (usually but not always) fussier, more sensitive to the quality of the rest of the system, and can have audible limitations on certain records, but (for me) overall worth the trouble and have the potential to get closer to perfection. But it will take more effort to every part of the system, so is it worth it? For me, lately, yes but I wouldn't hesitate to go with the Mark Audio's and would in fact recommend them to people who want more of that "plug and play" thing.
One last note: don't ever touch the metal cones, and don't crank them up too loud. Oddly, the Fostex sound so delicate, yet can take a ridiculous pounding -- but the Mark Audios (despite the very robust sound) are comparatively delicate and break-able. I've never blown a Fostex but have blown multiple Mark Audio's (not a criticism, that's just how it goes).
Old 10th October 2012, 01:27 AM   #28
With electronic music I can see more potential to damage speakers (true?) but by using subs do I reduce the chance of pumping damaging signal through them? Or are they just as sensitive to damage through mids and treble?
Old 10th October 2012, 01:40 AM   #29
Assuming a vented cab, bass causing over-excursion would be the danger, so if you high-pass them, personally I would think you would be fine.
Sadly, not all subs actually have a functional high-pass, but I hope yours do.
Old 10th October 2012, 01:58 AM   #30
I'm building them. Plan (now) is to have an active crossover with subs and full range speakers
18" TH Build Options fhperez Subwoofers 14 16th April 2012 02:13 PM
Pre - Options richluvsound Pass Labs 24 31st March 2011 06:54 PM
options please brucegseidner Power Supplies 3 5th February 2010 01:39 AM
Sheilded options for 2 way or 2.5 way UK Dave Multi-Way 4 21st April 2008 06:46 AM
CD Options? renfrey Digital Source 1 5th March 2007 08:18 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
