fostex recomended backloaded horn design for ff85wk
Old 2nd October 2012, 09:50 AM   #1
soundnovice is offline soundnovice
Default fostex recomended backloaded horn design for ff85wk
have anybody tried below design for ff85wk?
http://www.fostexinternational.com/d...e/85k_encl.pdf
Old 2nd October 2012, 10:27 AM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
It's not for the FF85wk, it's for the defunct FF85k. That said, it should be big enough not to be as heavily affected as, say, a more tightly aligned BR or similar. I wouldn't be particularly inclined to use the 85 in this way. It's a mid-tweet & gives its best when used with LF support.
Old 2nd October 2012, 10:32 AM   #3
thats what i thought too, but as in the design, using two units in parallel caught my attention.
Old 2nd October 2012, 10:39 AM   #4
ODougbo is offline ODougbo  United States
I've looked at this plan a few times, tempting. However I don't like that there are two drivers - that's like having 2 tweeters (per side).
Old 2nd October 2012, 05:00 PM   #5
chrisb is offline chrisb
if wanting to try the 85WK in a BLH, I'd be inclined to consider the FH3- one of mr Moose's more brilliantly flexible contraptions - but as he noted above, it tends to really shine when hi-passed (anywhere from 160 - 330Hz*) , and supported by stereo woofers
* even at the higher end of this range, the parts for high level passive can be bulky and not inexpensive - bi-amping with line level passive or digital ( MiniDSP / Behringer, et al) is well worth the extra time and expense, if only for the flexibility of fine tuning.
easy to say for a guy with all FR systems at home - my only XO consists of the DSP in Denon receiver.
like my mind, this space intentionally blank
Old 2nd October 2012, 06:38 PM   #6
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
We have speculated that a pair of FF85wk would work in FH3, but haven't yet had enuff free units to try the idea out. Do it with removable baffle and if it doesn't work out, any of the known working drivers can be subbed in.
But as Chris says, to really shine in anything but low level little bass required situations, they become a no excuses required system -- still won't move air like a set of 604s, but some people just don't have the room. I know for instance that Scott would love a set of 604s with dual 15" helper woofers, but is mostly restricted to his uFonken daily drivers (he has a pair of the same woofers Chris has in his HT, unused under his bed -- if he felt really bass deprived, they would have been in boxes long ago )
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd October 2012, 03:41 AM   #7
cost wise its more sensible to go for a bigger single driver (may be fe166En) rather than struggling with two smaller units! so dropping the idea. thanks for the inputs
Old 3rd October 2012, 05:14 AM   #8
zman01 is offline zman01  Bangladesh
soundnovice,
FE166En will have totally different cabinet requirements - the BLHs for that driver are pretty big IIRC,
Old 3rd October 2012, 03:06 PM   #9
Scottmoose's Avatar
Quite. And it's not necessarily 'more sensible' -it depends on what your requirements in the first place are.
I must be getting predictable in my old age. I'd love a set of 604s, although if I wanted / had the space (& money) for twin 15s, I'd probably go with a compression mid-tweet (all Altec, naturally).
Old 3rd October 2012, 03:15 PM   #10
GM is offline GM  United States
GM's Avatar
I'm surprised! Being British, I figured Vitavox would be preferred.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
fostex recomended backloaded horn design for ff85wkHide this!Advertise here!
fostex fe107e backloaded horn hendram Full Range 3 21st July 2009 02:10 AM
Backloaded horn with Fostex FE206E Arie Full Range 1 9th February 2008 01:28 PM
Fostex recomended back horn for FE108 E Sigma Andrewbee Full Range 10 3rd August 2007 09:49 AM
Large backloaded Fostex horn??? Circlomanen Full Range 13 24th April 2005 11:21 AM
