Driver Coupling
Driver Coupling
Old 28th September 2012, 03:01 AM   #1
FozzZ is offline FozzZ  Canada
Default Driver Coupling
I have never built a Fullrange loudspeaker system (working on on it though), so I'm never sure if the "rules" I build Multi way speakers by are applicable. Just about ever speaker I've build for home use uses some form of driver coupling. Where the rear portion (usually the magnet or backplate) of a speaker is attached to the cabinet to support the motor structure and decrease driver resonance. But for some reason, I see Fullrange speakers in the same way I view a violin or other string instrument. The resonances are part of the design. And because of this, I should stray from reducing them. This normally goes against the grain for Multi ways, where resonance equals coloration.
I will be building a set of Maeshowe's later this year, and I'm trying to get my ducks in a row before I move forward.
Old 28th September 2012, 01:40 PM   #2
fastbike1 is offline fastbike1  United States
Driver coupling is a feature of every Planet 10 design. Same for Woden Design
I was so much older then, I'm younger than that now.
Old 28th September 2012, 08:32 PM   #3
I don't see coupling of any kind in my drawing, but I will assume that I can go a head and couple the speaker.
Old 28th September 2012, 08:46 PM   #4
GM is offline GM  United States
GM's Avatar
Either the driver is a reproducer [braced] or a musical instrument [unbraced], so whether to brace or not depends on the app/personal preference.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 28th September 2012, 08:57 PM   #5
sippy is online now sippy  United Kingdom
P10 designs feature a vertical brace that joins the front to the back and top to the bottom. Careful cutting of the notch for the motor assy to sit against PLUS slight shimming puts things under VERY slight compression when the drive unit is bolted in place, its simple and it works, I know this 'cos my EmKens show no signs of buzzing in that area....... not that I'd be stupid enough to wind the loud dial to find out!
Old 28th September 2012, 11:48 PM   #6
tvrgeek is offline tvrgeek  United States
There is no difference in the physics between full and multi driver systems. There seems to be two camps, really braced and as de-coupled as possible. Just one more thing to test one of these days.
Old 29th September 2012, 01:36 AM   #7
^^^^^part of me assumed this, but Fullrange still had/has some sort of "magic" that I dont understand. Which s the main reason I've been posting so many questions lately.
Old 29th September 2012, 03:55 PM   #8
My mistake on the Maeshowe. My personal choice is to build to the design. In this case Scott shows the driver uncoupled. I generally assume that I don't know more than the designer, otherwise I would be making my own design.
FWIW, another popular speaker design forum rarely has multi-way designs that coupled the driver. Well braced cabs to be sure, but no direct driver coupling. I am personally as yet unconvinced that it makes an audible difference with a well built cabinet, but as stated, I defer to the designer.
Old 29th September 2012, 04:55 PM   #9
No magic in speakers. Just physics.
Old 29th September 2012, 05:19 PM   #10
chrisb is online now chrisb
well, just because some folks "understand" physics, doesn't mean it's still not magic to the rest of us
I'm still amazed that a (few) piece(s) of paper / plastic / metal foil moving back and forth can coax my brain into reconstituting such an emotionally satisfying illusion
but then it's a very simple brain - it doesn't understand physics
like my mind, this space intentionally blank
Driver CouplingHide this!Advertise here!
offset driver with coupling chamber/throat chamber: possible with MJK mathcad models? gafhenderson Full Range 0 30th March 2012 11:35 PM
A.C vs D.C coupling Neil Groves Analog Line Level 7 17th September 2011 02:50 PM
Coupling caps. Trebla Class D 5 1st March 2006 09:12 PM
direct coupling 2a3maniac Tubes / Valves 11 2nd February 2004 07:19 PM
What does coupling mean? EternaLightWith Tubes / Valves 53 5th January 2003 09:35 PM
