Quick 'n fast- F.A.S.T - Page 4 - diyAudio
Old 10th October 2012, 04:23 PM   #31
frugal-phile(tm)
planet10's Avatar
Originally Posted by jameshillj View Post
Harry Olson's 8" RCA LC-1A
It is a 15"
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th October 2012, 05:04 PM   #32
Melo theory's Avatar
Originally Posted by Bob Brines View Post
What ever. The point is that cone breakup has to be well above 1kHz.
Bob
Well, we don't have to use a 1st order crossover. It would be nice, but not necessary.
I LIKE YOU
Old 10th October 2012, 06:39 PM   #33
mondogenerator's Avatar
Vix, im interested to know which 3" fullranges you have used with a 1st order HP at 300hz. I have TB W3-1285SG and MA A6, and NEITHER worked well at all high passed 1st order. I found 2nd order HP and 1st order LP worked far better at 300hz or thereabouts. Even with 47uf single cap giving a higher F3 didnt work well. Unless the driver Z at Fs is flattened i dont have much confidence in what you claim.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 10th October 2012, 07:00 PM   #34
frugal-phile(tm)
planet10's Avatar
A thread for Tysen and variations on FAST
We went active with Tysen, but a similar mid-TL worked well with a 1st order series XO at a bit above 300 Hz.
dave
Old 10th October 2012, 07:22 PM   #35
tuxedocivic's Avatar
Dave, that is cool. I wonder though if the actual acoustic slope would have been closer to 150hz on that one. As the filter engages the z peak at 200hz would resist the filter and then as it comes off the peak toward 150hz the filter would fully engage. I'm not sure that's how to technically describe it, but it's how my thought process works.
Edit - nevermind. You said series. I'm not sure how things would be effected.
Old 10th October 2012, 08:52 PM   #36
Bob Brines's Avatar
Of course, you don't have to do 1st order and you don't have to cross at 300Hz. Where you cross is dependant on all of the other parameters of you speakers/room. You do need substantial overlap, even 4th order and you want the woofer cone breakup as far down as possible. But then again, you want to unload the FR as much as possible, and you need the phase rotations as low as possible. These are conflicting requirements. You simply play with it until is sounds right. Hence the beauty of DSP.
Bob
Old 11th October 2012, 06:25 AM   #37
nice post Dave, it illustrates my point perfectly. Aperiodic mid loading, or impedance conjugate is the only way i can see a 300hz xo working well with a 3" driver. Clearly filtering at the preamp stage is the only way to cross 1st order and get the correct filter slope.
DBX RTA-M measurement mic,M audio fast track usb. Quick sale tomat Swap Meet 6 21st September 2011 04:09 AM
Fast sub anyone? cr0wl3y Subwoofers 63 29th May 2010 04:42 PM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 05:20 PM
THAT was fast DragonMaster Everything Else 0 25th August 2006 06:52 PM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 10:00 PM
Copyright 1999-2017 diyAudio
