Old 26th September 2012, 06:14 PM   #1
kec is offline kec  United States
kec's Avatar
Default Eminence 12LTA + Supertweeter (coax style)
I've been working on an OB Beta 12LTA over Alpha 15 H frames. I know, that's not full range, but thought you full rangers might like this as well.
I finished the tweeter pods that mount to the pole piece on the 12LTA. Thanks go to Ron Brady over at the fullrangedriver forum for the idea. The Lanzar DCT's are available on ebay for $15 shipped. They have a supposed 96dB SPL. I'm currently using a 4.3 uF Solen cap that I had on hand. Ron recommends 4 uF high quality cap.
I used three 1/4" x 1/4" round neo magnets to secure the pod to the pole piece. It's strong enough to hold it in place. And, of course easliy removed if needed. I initially tried a big flat washer, but it won't work.
The bottom of the 2" diameter 1-3/4" long PVC is a piece of 1/8" thick garolite. The bottom is fastened to the PVC with JB weld. The magnets are also fastened to the garolite with JB weld from the inside. The most important part is to make sure the magnet poles are installed correctly before gluing them in. Sanded the pipe and shot some Krylon Fusion satin black.
I used the flat surface mount base from the Lanzar kit (there's 3 different mounts - surface, angled, flush). The base is also fastened to the top of the PVC with, you guessed it, JB weld - hey I like it. Using the base allows you to remove the tweeter easily.
Here's some pics...
Intel D410 mITX > Foobar > Musiland 01 USD > Gigawork DAC > Crown XLS1000 > Manzanita Ultra
Old 26th September 2012, 08:02 PM   #2
sippy is online now sippy  United Kingdom
As I'm a beta tester for the P10 EmKen, this very interesting.
Old 26th September 2012, 09:04 PM   #3
PKI is offline PKI  United States
PKI's Avatar
Could you please upload some photos of the back(magnet) of the speaker?
Old 26th September 2012, 10:45 PM   #4
JRKO's Avatar
Send a message via AIM to JRKO
I too am running the Emken. Very interesting indeed
And the sound?
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home
Old 26th September 2012, 11:05 PM   #5
mightym is offline mightym  United States
mightym's Avatar
Location: Checotah, Okrahoma former home of the Okra Fest
I did a couple of web searches several months ago, when considering my own Beta 12 LTA project.
At the time, I was able to find a small number of Automotive tweeters like the Lanzar ( which was one of them ). My own minimum requirement called for very high efficiency, and preferably a fabric dome.
I'll see if I can find my notes, and post the other choices I found.
My recollection was that they were all inexpensive enough to pick up all of them to try. I planned to use a bit of wooden doweling as my mount ( closet rod ). One of the reasons I backed off the proposed project was fear of ruining a $60 driver trying to drill through the pole piece to run the tweeter wires. I second the request to see the magnet, and would love details on how you did the deed, if you drilled the pole bit of the driver...Blow by blow if you please...
My own were to go into a cabinet inspired by Thuras/Onken resistive vent much like the Emken, only different in that the vents would have surrounded the driver on the front face of the baffle.
Let me see if I can find those notes.
I'll be following this thread with interest....
John
BTW, Kudo's on the nice looking work, kec. How do they sound???
Old 26th September 2012, 11:17 PM   #6
mightym's Avatar
I found my notes, and could even decipher the intent of the design! Still!!
Here's the order I recorded them in, I didn't record the effficiency/ dome material/ Etc. though.
Lanzar DCT
Power Acoustik NB 1,2,or 4
Absolute TW-800
Boss TW-18
Boss TW-20
Hitron HS-200
As I said previously, I can't recall much else about the idea, other than high enough efficiency to mate with the Beta 12 LTA, and my own preference for fabric dome's over metalic. Though as a rule I prefer horns to domes. To each his own...
I can't vouch for the quality of any of these, and would have to defer to someone who's actually used/heard them as to SQ, and suitability. I was just chasing an idea to see where it went at the time. I only list these here to possibly help someone else who may have the guts to take a brand new driver and poke holes in it!
John
Old 26th September 2012, 11:42 PM   #7
PKI, the 12LTA has a big hole right where you want to drill. Round the back is a gauze covering the hole, to remove, screw in a wood screw and yank it (and the lil gauze/screw)
Old 26th September 2012, 11:51 PM   #8
frugal-phile(tm)
planet10's Avatar
I am going to do something similar with mine using the FT17.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th September 2012, 11:53 PM   #9
Dave, wont the 66mm dia of the motor get in the way - or will you blend the tweeter into the support like a light bulb shaped plug?
Old 27th September 2012, 12:00 AM   #10
mightym's Avatar
wouldn't this cause phase issues?
Eminence Beta 12LTA Enclosure ebag4 Full Range 8 1st September 2012 04:01 AM
Eminence Beta 12LTA new pr $120 bigaudioscotto Swap Meet 2 5th August 2012 01:30 AM
Eminence beta-12lta on OB? grantnsw Multi-Way 0 8th January 2010 02:38 PM
Fostex FE127e. Eminence 12LTA. nodiak Swap Meet 4 4th January 2009 04:30 AM
Eminence Beta 12lta Glenn Swiderski Multi-Way 5 9th December 2003 01:31 PM
Copyright ©1999-2013 diyAudio
