3"or 4" driver with very good dispersion and high xmax?
Closed Thread
Old 28th September 2012, 06:32 PM   #41
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Seems a pretty complete description of how they were measured to me. What more do you want to know? Mark may have given a bit more detail in his Alpair 7.3 thread.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th September 2012, 06:39 PM   #42
markus76 is offline markus76  Germany
Banned
dave
Maybe I missed it but what is the mic distance, test signal, frequency resolution, smoothing, windowing, driver mounting?
And again, I believe it's important to look at all angles and not just 0-30. The walls in our rooms care about other angles too
Old 28th September 2012, 06:50 PM   #43
frugal-phile(tm)
planet10's Avatar
No smoothing AFAIK, likely 1m mic distance since that would be far-field for a 4" driver (ref Toole: measurements need to be taken in the farfield and scaled to 1m distance), driver mounted in an IEC box, with thin aluminum baffle. Taken with LEAP i believe.
Measures ideally go out to at least 90 degrees, but still this is better than just on-axis.
Go over to the Mark Audio forum and ask him for details.
dave
Old 28th September 2012, 07:00 PM   #44
Banned
Well, I thought people here actually have measured drivers themselves that's why I've started the thread.
Old 28th September 2012, 08:04 PM   #45
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
Here is the off axis of the EL70.
Take a look at the bunching happening at 5khz. People who know more about driver mechanics than I do could say, but I think this is indicative of the first signs of cone breakup. The phase is changing from the outside of the cone relative to the inside. It may also be related to moving the treble onto the dustcap. Either way, that spreadat 3khz followed by gathering at 5khz would technically be considered bad.
Despite this, you can see that it has uniform dipersion up to the top octave out to 45d. It resembles the alp7. This is a Mark Audio built driver, and some here (Dave?) may be able to tell you if it's similar to the alp7 cone. I believe the alp7 cone is superior because it's a later gen product, and my ears tell me it is
EDIT - note my measurements are on a 5db scale and Mark's are 10db, just so it isn't confused. They're actually fairly similar (trends).
Old 29th September 2012, 05:00 PM   #46
tvrgeek is offline tvrgeek  United States
Many do. The big advantage in DIY is we can measure in OUR box, our baffle etc. I only worry about 15 degrees. because I know how I am going to use my speakers.
Old 29th September 2012, 05:28 PM   #47
Banned
In an unechoic chamber?
Old 29th September 2012, 07:18 PM   #48
Are you interested in the sub 200hz or something? 200hz+ is pretty easy to get. I just measured an SDX7 woofer outside with reasonable accuracy down to 150hz. Then do a near field for 200hz down.
Old 13th July 2013, 11:29 AM   #49
Banned
Hi guys,
Sorry for reviving an old thread but can anybody provide off-axis data for the Tang Band W3-1797S?
Any other interesting new 3" drivers with wide dispersion and high SPL capabilities on the market?
Old 17th February 2014, 01:54 PM   #50
Banned
This is a nice one:
dave
Here's the Alpair 7.3 in a 43x43cm box from 0 to 90:
3"or 4" driver with very good dispersion and high xmax?-alpair7-3-0-15-30deg-png
(90cm mic distance, gated at 4,7ms)
Looks like a totally different driver.
Here's 0-90 - pretty ugly:
3"or 4" driver with very good dispersion and high xmax?-alpair7-3-0-90deg-png
Closed Thread
3"or 4" driver with very good dispersion and high xmax?Hide this!Advertise here!
Woofer "Speed," high Xmax vs. low Xmax in Uframe and Sealed Enclosures jarvissound Subwoofers 35 21st March 2014 10:48 PM
BLH w/ High Xmax Driver??? goody75 Multi-Way 3 18th December 2011 07:48 PM
four inch driver with good efficiency and low Rms/high Qms? twest820 Multi-Way 23 18th August 2010 03:55 AM
In general, how to get good dispersion? cuibono Multi-Way 2 26th August 2008 07:45 AM
12" driver with big Xmax,low Fs, & high efficiency? WolfmanX Multi-Way 18 26th November 2002 11:10 PM
Copyright ©1999-2017 diyAudio
