MARTELLO-2, a mini-tower from a single 2' x 4'
Old 21st November 2012, 02:17 AM   #51
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
A different rebate.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd November 2012, 12:57 AM   #52
Bigun is offline Bigun  Canada
Bigun's Avatar
It was an interesting thought, but looking at the spec sheet the diameter of the front bezel for the A7 is 135mm and for the EL-70 it is 124mm. So it won't fit because the boxes I have are already narrow enough for the EL-70 and wouldn't accept a larger diameter rebate.
I will do some more listening with the EL-70's. I realized that the listening tests done earlier had the speakers wired up to the 8 ohm tap on the amplifier, I should try the 4 ohm tap.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 22nd November 2012, 01:34 AM   #53
frugal-phile(tm)
planet10's Avatar
If you can fit the EL70, but not the A7 then the enclosure is likely too narrow and will suffer from early reflection and give a cupped midrange sound.
dave
Old 22nd November 2012, 05:40 PM   #54
Bigun's Avatar
It is definitely on the narrow side, this was a design decision made at the outset, a tradeoff between performance and 'customer requirements'. But I believe it will be acceptable if the treble were to improve with break-in and perhaps with properly matched amplifier.
Old 22nd November 2012, 11:59 PM   #55
frugal-phile(tm)
planet10's Avatar
THose wo't help with a problem with cuppiness caused by sides too close... it was an excercise we wentthru when we did the 1st milliSize enclosure... as little as a cm made a significant difference.
dave
Old 3rd December 2012, 01:11 AM   #56
Bigun's Avatar
I have move the SV811 amplifier to the room where I keep my Big'un speaker, the AN15. And it also allowed me to use my Magnum Dynalab FM tuner. Both the tuner and the large speaker are in daily use so I'm more familiar with their sound - through my Cellini SET.
Speaker cables changed, no longer the fancy Zu cables but my DIY lamp cord from Home Depot. Again, more what I'm used to listening with.
the Martello-2 once again provide a first impression of impressive bass simply unexpected from small speakers. The overall sound was very pleasing.
I compared the FM tuner with my YBA CD player - noticed the usual limitation with modern popular FM stations sounding like MP3. Only the French channel sounds really good. The CD player sounds better. But then I haven't upgraded the stock electrolytic output caps in my tuner yet (a story for another day).
The treble did not sound distorted from the Martello-2's, cymbals were clear.
Switch over to the Big'un, using both outputs of the amp in parallel. The bass goes deeper but it's no more powerful (mind you, the speaker still has no back on it). However, I did notice that that the sound opened up, it does have a more open lower and upper treble compared with the Martello-2's. Perhaps not quite as smooth though, a little roughness in the treble - the AN15 has yet to receive the Bud P. treatment.
So, I'm still left mighty impressed with the what the Martello-2 cabinet does for the bass, but not yet sure if the EL-70 is providing the treble it should be. More running in is still needed to be sure.
Old 16th February 2016, 06:32 PM   #57
frugal-phile(tm)
planet10's Avatar
Originally Posted by Bigun View Post
The design will also work with the CHR-70 so that if one of her dogs destroys the EL-70 drivers there is a current-production driver available to retro-fit (with some minor adjustments).
Ignoring issues with monting the driver, the new Pluvia Seven (P7) should pretty much drop in.
Updated link to microTower:
http://frugal-phile.com/boxlib/P10fr...aps-020615.pdf
dave
Old 16th February 2016, 06:56 PM   #58
Bigun's Avatar
She wasn't going to trust her dogs so the speakers are still with me. She took a pair of my original Martello speakers, the desktop sized units.
I'm considering using the Martello-2 speakers in a new set-up, as I have myself an old turntable (no vinyl to play on it yet and no clue as to how to set up the turntable either) plus I also recently got an old Marantz receiver with a phono amp inside it so I can put it all together one day.
Old 16th February 2016, 10:07 PM   #59
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Set up a turntable? Don't go there -that way lies madness! To be honest, that's why I don't have one. I'd spend more time worrying about the VTA or springs than listening to music. The old '70s DD models were great for that: compared to a belt-drive or similar, practically plug & play.
That said, I'm going to buy a Mitchel Hydraulic Reference from a friend, once I have sufficient room for it. Not to use, obviously. Just to look at.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 16th February 2016, 10:39 PM   #60
Bigun's Avatar
well I found this Pioneer PL-2 on eBay when I was messing around, it was on offer for not-a-lot and I just clicked on it. Next thing I know, I'm in to vinyl
Now I can look cool next time I see a stack of vinyl on sale, I can flick through and pretend I've heard of some of the artists !
Mostly I listen mono, but with a stereo TT, this stereo Marantz thing that also came off eBay I will need stereo speakers. The Martello-2's will do nicely.
MARTELLO-2, a mini-tower from a single 2' x 4'Hide this!Advertise here!
Martello enclosure for FR88EX Bigun Full Range 218 30th January 2017 01:59 PM
Martello Fr88ex awqawq Full Range 6 26th August 2012 11:24 PM
2' x 2' x 4' TH sub feasibility? aceinc Subwoofers 14 29th October 2010 09:12 PM
Micro Mini Desktop Tower Plans roadsterdriver Full Range 24 18th September 2009 06:42 PM
Small Speakers 4' Krisfr Parts 11 7th September 2009 12:44 AM
Copyright ©1999-2017 diyAudio
