MARTELLO-2, a mini-tower from a single 2' x 4'
Old 7th October 2012, 08:43 PM   #31
Bigun is offline Bigun  Canada
Bigun's Avatar
So the stuffing is done. And the backs have been glued on. The sides at the back have been routed flush. Holes were cut for the terminal cups and a wire put in before gluing the backs on of course.
Now just routing the bottom edges uniform before cutting the breathing slots.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 7th October 2012, 10:24 PM   #32
Bigun's Avatar
So I finished the bottom pieces with 2" plastic pipe. I cut the lengths to around 5.5 inches - being a compromise between the EL-70 and CHR-70.
I held the speakers upside down to saw for the breathing slots, cutting to the depth needed minus radius of my router bit. Then I used a finishing router bit to route the breathing slots, using the screwed on bottom pieces as a guide for the router bit.
Now the basic construction is done - next step is sanding, tidying up, staining and varnishing.
Old 8th October 2012, 11:18 PM   #33
Bigun's Avatar
Progress....
The bottom pieces were finished up and mounted into the base of the speakers. A couple of coats of Dark Walnut gel stain and they're starting to look ready for action
Old 9th October 2012, 02:19 AM   #34
sippy is offline sippy  United Kingdom
Those are looking good
Old 11th October 2012, 12:32 AM   #35
Bigun's Avatar
Thanks Sippy!
Well they are now in song.
And for the first time I understand why people rave about the bass of these drivers !
The photo shows the Martello-2's flanking my new Big'un speaker. They don't compare with the AN15, but they do a very good job of it.
I'm not sure I'll need to be doing any tweaking.
This could be a case of "It's a wrap!"
Old 11th October 2012, 12:45 AM   #36
chrisb is offline chrisb
and when you double up ...
nice work
kinda burnt out - taking a break
Old 11th October 2012, 12:50 AM   #37
Bigun's Avatar
Two drivers per side - that would be really nice !
Anyhow, I'll listen to them for awhile. No doubt I'll find myself wanting to go back to the AN15 eventually but they do well for their size.
Old 12th October 2012, 12:34 AM   #38
Bigun's Avatar
I now have it on good authority that the WAF factor for these speakers, being narrow and not too tall - is extremely high
Old 12th October 2012, 12:58 AM   #39
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
well I haven't found it easy making the 45 degree mitre cuts using a hand-held circular saw
Bigun my friend!
It's not that hard if you use a Swanson square as a guide. Freehand you have to be either a miracle worker or an idiot to try.
planet10 needs your help:
Let's help Ruth and Dave
Old 12th October 2012, 01:53 AM   #40
Bigun's Avatar
I used a guide, a piece of wood clamped on top of the piece I was cutting and ran the edge of the baseplate of my circular saw along this guide. But you know, the slightest wobble of the saw and the cut is slightly off. Over a 30+ inch long joint you have to be spot-0n for two of these 45degree edged planks to make perfectly. So, I'm afraid my workmanship just ain't up to it !!! - but following-up with the router made things 99% good.
MARTELLO-2, a mini-tower from a single 2' x 4'Hide this!Advertise here!
Martello enclosure for FR88EX Bigun Full Range 218 30th January 2017 01:59 PM
Martello Fr88ex awqawq Full Range 6 26th August 2012 11:24 PM
2' x 2' x 4' TH sub feasibility? aceinc Subwoofers 14 29th October 2010 09:12 PM
Micro Mini Desktop Tower Plans roadsterdriver Full Range 24 18th September 2009 06:42 PM
Small Speakers 4' Krisfr Parts 11 7th September 2009 12:44 AM
Copyright ©1999-2017 diyAudio
