W5-1611 SAF - The Sequel
I see a few folks have tried different designs for the W5-1611SAF, so going to try my luck.
Since I typically dance to the beat of a different drum here is the direction I'm headed.
I had a few ideas but was inspired by plans found here (post 13):
http://www.diyaudio.com/forums/full-range/188620-onken-near-field-monitor-2.html
AND other full range boxes with a W shape & flare ports. This will be a combination of both (similar to red box). The tuning will be done on the work bench by trimming the flare ports. Not easy to see in pic. but glued 4 pieces of 5" x 1/2" poplar that will be cut/fit/sanded and again, trimmed as needed.
Cones are coated - thin layer of RTV 118.
Speaker Driver: http://www.tb-speaker.com/detail/0624_11/w5-1611saf.htm
Good to see that are coming right alone.😀 Let us know how they sound in your cabinets. I heard the W5-1611SAF drivers but, they were new and not broken in yet. Sound fine. Let me know Jm
We did hook my pair to the living room TV - again, they do sound very nice, but not a lot of high end.
[Neighbor stopped in -- he never heard any that good before 😱 ]
I suspect the dots would be better then a full coat of silicon (like I did).
Truth be known..I gave up on the high end on these. I like them much better with a tweeter (Morel).
For a xo went to on-line calculator; used a 2nd order Butterworth (180 phase shift for tweeter). The xo is point is close to 2200hz.
Folks...the W box with the front ports is a keeper; getting really nice bass out of them.
So, now you have an two-way speaker, not an fullrange anymore.
