W5-1611 SAF - The Sequel
Old 19th September 2012, 04:15 PM   #21
ODougbo is offline ODougbo  United States
I needed a REASON to go to HD.... Oh boy morning brain freeze.
At least I didn't type raisin.......
I have moretile on the brain, have full box of that, which is very sticky.
Old 19th September 2012, 09:28 PM   #22
Gave this a quick check to see if I'm the right ball game.
The 13mm slot vents (wood pieces) are big enough, was a little worried about that.
As it sits here, the Fs is 45hz (too low) can simply trim vents down to raise it.
Generator & volt meter test:
35hz @ 4 volts
45 valley
85hz @ 7 volts
Going strong to 50hz, there is a dip around 100hz, but haven't trimmed/raised the tuning yet.
The speaker sounds pretty smooth
Old 19th September 2012, 10:53 PM   #23
Trimmed ports to about 4" wide (cut about 3/4" of each one)
Looks good:
38hz @ 6v Peak
50-51hz Valley
80hz @ 7v Peak
Old 20th September 2012, 09:49 PM   #24
Had to square up the vent pieces anyway ...4" I wish I had known that.
It took at lot of trimming to move up the Fs, which is now 52hz
Old 20th September 2012, 09:57 PM   #25
Now chrisb... What was I saying about extra glue and solid construction?
For the DIYers, you don't need a dozen clamps; blocks of wood and weight will do the trick. Buckets of sand, whatever........
Old 21st September 2012, 11:29 PM   #26
Default The Odoug Bro II
Pic
Old 21st September 2012, 11:36 PM   #27
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Nice!
Old 21st September 2012, 11:59 PM   #28
woodshop was the only class I got A(s)
Or just ahead of my time ;-0
Old 22nd September 2012, 03:13 AM   #29
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Doug,
Sure looks like you "KEFed" those majorly...
Mine are ready to try out again.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd September 2012, 10:04 AM   #30
Thanks Dave...all ready staying up at night thinking about dots
My drivers are a little different, they have a flat back (magnet) which I might glue cork on.
I might re-do the silicon; it looks messy now, will try a softer brush. Will slip a piece of paper in the VC for protection.
My son stopped by, I had Alan Jackson on; he was amazed at the sound.
[all my good CDs got stolen at work, so using sons collection. The Alan Jackson CDs are very well done recordings (btw, he has 50 top hits). I never would have thought light country would sound good on small, single cone speakers]
They do sound very nice, I didn't hear the "plastic" sound. They are dipping down pretty low; sound like a 7" in a BR box. However I want to raise the bass level just a bit, just for the wow factor. I'll try a BSC. Although, the bass really dips down (sub woofer territory) 20' away....wavelength I guess
All said, they didn't quite have the same depth and imaging as the fostex with the mods, not bad though, might make some more.
btw, ordered the expensive wool $50 bucks, its not fluffy enough; 7oz just filled 1/2 the box, so I tuned them upside down (gravity). Back to the craft store, might have to open a few bags; they have racks of different textures.
W5-1611 SAF - The SequelHide this!Advertise here!
BVR for TB W5-1611? chazdrumzalot Full Range 8 22nd April 2011 05:16 PM
ML-TL for a TB W5-1611 6b4g Full Range 0 9th January 2011 04:47 PM
Just finished desktop OB Tang Band W5-1611 mayhem13 Full Range 4 2nd December 2010 07:37 PM
Tang Band W5-1611 Question Dxvideo Full Range 5 15th March 2010 09:35 PM
Anyone built a TB W5-1611 Horn? Herr_Mo Full Range 3 2nd July 2009 09:10 AM
Copyright ©1999-2017 diyAudio
