W5-1611 SAF - The Sequel
Old 16th September 2012, 09:59 PM   #11
ODougbo is offline ODougbo  United States
yup. easy to do. Don't put too much on, spin around as you work.
Better if speaker is out of box.
Turn upside down to dry; especially if voice coil is "open"
Can find it on ebay OR here - remember 118. Its on the second 1/2 of page:
McMaster-Carr
Old 16th September 2012, 10:03 PM   #12
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Originally Posted by ODougbo View Post
Jeff, went back to WinIsd, found out could not work vent sizes in inches - used mm and then had to trick the widow and start high and work my way down. [kept losing the response line]
Yes, a couple of annoying glitches.
I took grindstone's numbers and ran another sim using your vent sizes. Box is 18.5L @57Hz tuning. You'll notice the vent length is quite a bit less, due to the higher tuning.
jeff
Old 16th September 2012, 10:44 PM   #13
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Fs is 20hz off? I'll check that here.
Likely that grindstone is just measuring at a different part of the T/S curves. Computer driven measuring kit is often this far off factory measures (my own included -- i always start with the factory numbers).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th September 2012, 07:43 AM   #14
grindstone is offline grindstone  United States
grindstone's Avatar
Default FWIW
Mine were neo's and over a year ago. Second, I'm not far from Dave's position--I hedge somewhere betw mfr data and what I measure when doing sims.
Old 17th September 2012, 09:42 AM   #15
I had planed on finishing these this weekend, no such luck.
Might have them together in week or so. However, so far so good, I like the proportion.
Top is not glued - only glue one "side" at a time (I don't like glue running all over).
Old 18th September 2012, 09:51 AM   #16
Default Picking up speed
Picking up speed, but only have a few hours into this so far. Going to tune it up today.
The white screen is a blocker to keep the damping material from blocking the ports; found it in our last pizza box order. I may have to go order another pizza for the second one.
Will probably just throw the pizza out and keep the white screen - the pizza was terrible
Old 18th September 2012, 07:00 PM   #17
So forum question, is the full range woofer too low?
Not glued, could cut another front baffle.
I do like TVR's "rounded over" thoughts.
Old 18th September 2012, 11:55 PM   #18
More fun than a barrel of monkeys
What is more fun than building speakers while listening to good speakers?
whew I needed a fix
Old 19th September 2012, 10:33 AM   #19
Default Gaskets
I'd much rather pay an extra dollar for factory gaskets, vs. making them. One resin not to buy less expensive speakers, have to spend more $$ fixing them.
Might put some hard wood on L&R panels (for looks).
So far so good.
Old 19th September 2012, 02:56 PM   #20
frugal-phile(tm)
planet10's Avatar
Just use draugh eclusion tape (weather strip). Home despot has nice neoprene stuff. THis is what the KEF drivers of yore shipped with.
dave
W5-1611 SAF - The SequelHide this!Advertise here!
BVR for TB W5-1611? chazdrumzalot Full Range 8 22nd April 2011 04:16 PM
ML-TL for a TB W5-1611 6b4g Full Range 0 9th January 2011 03:47 PM
Just finished desktop OB Tang Band W5-1611 mayhem13 Full Range 4 2nd December 2010 06:37 PM
Tang Band W5-1611 Question Dxvideo Full Range 5 15th March 2010 08:35 PM
Anyone built a TB W5-1611 Horn? Herr_Mo Full Range 3 2nd July 2009 08:10 AM
