empty b&w 805matrix cab, what to do?
Old 15th September 2012, 11:39 AM   #1
panduro is offline panduro  Denmark
Default empty b&w 805matrix cab, what to do?
So i got a pair of b&w 805 matrix enclosures for free, no drivers, no xover just the empty shell for the bass/mid driver. its a nice, heavy and wibe dead enclosure.
original driver was a mid/bass 130mm (5.4"), enclosure size 10,5L acording to review on stereophile.
B&W Matrix 805 loudspeaker | Stereophile.com
was thinking of entering the one driver world
What driver availeble in eu would you put in those two boxes? doesnt have to play very loud or very low, will be uses as a bedroom speaker with holfi cd and 45W integrated amp.
price 2 drivers: hmm max 270euro/350usd, less is also good
best regards
bent
Last edited by panduro; 15th September 2012 at 11:42 AM. Reason: adding intended use of speaker
Old 15th September 2012, 11:49 AM   #2
bambadoo is online now bambadoo  Norway
165mm (6.5") Kevlar-cone woofer with 3" voice-coil.
I had m805 for many years. Great speakers.
Much better than the later iterations.
best regards
bent
Old 15th September 2012, 12:00 PM   #3
thanks for your reply,
hmm refering to original driver? the cutout for flushmounting of the driver is 17cm and the hole is only 14,4cm so a 16,5cm driver woudnt fit
had original m805 ten years ago, and it was a great speaker.
best regards
Old 15th September 2012, 03:33 PM   #4
loninappleton is offline loninappleton  United States
A new cutout can be made with the usual tools for these tasks if you have them. Going bigger from smaller is easier. A new baffle front can be simply glued in place or used as a guide temporarily. Then use your cutout device whether it be jig saw router or zip tool with cutting blade.
Old 15th September 2012, 03:51 PM   #5
got a router, so no problem in going bigger, just dont know what to drop on the hole...
thanks for the replies.
best regards
Old 15th September 2012, 03:55 PM   #6
tom1356 is offline tom1356  United States
The drivers and crossovers are still available from B&W.
For about $700-800 you could make them whole again.
For ~$500 you could get the woofers, run them full range and save for the rest.
My "cult-like" following is accepting applications.
Old 15th September 2012, 04:16 PM   #7
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
10 1/2 liters. I'd somehow actually measure the volume, i wouldn't take Stereophile's guess as gospel.
From the drivers i am well familiar with a tiny bit big for Alpair 7.3, Fostex FF125wk, CHR70, CHP70 (easy enuff to add some solid fill), a bit small for Alpair 10.2, EL70, CHP70.1, but can all be made to work. TB W5-1611 might work (i haven't looked into boxes for this one yet)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th September 2012, 04:18 PM   #8
Hi tom,
thanks for your suggestion,
i once asked the danish b&w retailer to buy a new tweeter, price was 245usd
2 tweeters 490usd
2 tweeter housing's ???
bas/midrange drivers ???
xovers
i will ad up to more alot more than 800usd, its a bit more than my 350usd limit .
any suggestions on fullrange drivers that would be worthy of these enclosures?
best regards
Old 15th September 2012, 04:41 PM   #9
Hi planet10,
first of, the part of the baffle where i can mount the driver is 22cm(8,6") wide.
second, im looking for something that is easy, so not sure if can be made to work is something i should be after .
The matrix structure makes it very har too measure accurately.
the enclosure with wall thickness(16mm) deducted is 18L, the matrix structure is 6mm thick, some has holes in it, some doesnt and it fills the enclosure...
but youre right, 10,5 does sound a "bit" of
any good suggestions?
best regards
Old 15th September 2012, 05:10 PM   #10
i can only buy the tb driver en eu e-shops(i think)
what can i expect from a fullrange driver this size?
tb- sealed 11L, qtc 0.65, f0 apr.200 f3 apr 100hz f5 80hz almost "same" in 15L.
ported: only way to get it "flat" before roll of is to tune it below its fs, thats no good right?
best regard and sorry fore the newbee questions
empty b&w 805matrix cab, what to do?Hide this!Advertise here!
Coustic Design Reference Amp 514-DR empty ic quick connect ivkata Car Audio 3 8th April 2012 05:45 AM
Who had the 3-way dipole with the empty baffle? 454Casull Multi-Way 2 15th July 2011 03:47 PM
Empty molded cabinets? FlipC Subwoofers 19 3rd January 2011 05:48 PM
what sounds best . . . Low Qts in small cab or higher Qts in bigger cab mikelm Subwoofers 18 15th July 2009 10:46 AM
I want to build an amp cab chrislawrence42 Instruments and Amps 3 29th December 2003 09:31 AM
Copyright ©1999-2017 diyAudio
