#11 |
I would am willing to give anything a try if it's not to hard for a common man to build. Thanks jdm.
#12 | ||
Although the 206 is larger than the type of wide range generally used, one of the options of course would be an OB with supporting woofer - about as simple an "enclosure" as possible. Of the types that we'd more conventionally think of as "enclosures" , the first that come to mind would be BIB, Metronome, Kirishima (FrugalHorn Spawn) and Woden Vulcan - none of which would be smaller than the Fostex BLH, but all of which would use less material. The BIB would be a particularly simple build in terms of number & complexity of cut parts, but the operative word for this class of boxes would be Big, so some help would be helpful during the final stages of assembly, and certainly for moving / placement. If for no other reason than the weight, I'd highly recommend plywood over MDF for any of these designs. And, no I've not heard any of these design families with the 206, but have done with various other models and makes. BIB: Godzilla's site hosting the details of this design is not currently active, but no doubt he or someone else could forward the details / drawings Metronome: The Metronome Kirishima in this plan set: http://p10hifi.net/FH/downloads/Spaw...set-070412.pdf Vulcan: Woden Design | Vulcan (subscription applies to this design) and finally, if you've not already experienced them, be aware that some folks might consider the 206 in need of "helper" tweeter
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#13 |
Thanks for all the info I will look into it. Thanks again jdm
#14 |
Sorry for my bad English, is there a project just for Dallas II 206en, not 206E?
#15 |
Yes I think there is a project called the dallas 2's? If I recall right. I think I saw them on you tube looking up designs for the fostex fe206en drivers. Thanks jdm
#16 |
Can somehow connect with Ron?
#17 |
frugal-phile(tm)
FE206En should be fine with Dallas
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Best enclosure for Fostex fe206En | ARIYAHOOR | Full Range | 31 | 5th August 2012 10:06 PM |
| fostex FE206En | cone head | Full Range | 7 | 6th December 2011 10:06 PM |
| Can the Fostex FE206en be used in the Sachiko? | chengroger1 | Full Range | 1 | 13th June 2011 05:16 PM |
| fostex FE206En fr driver | cone head | Full Range | 3 | 6th August 2010 09:37 AM |
| anyone get/analyze (stock Fostex) FE206En? | freddi | Full Range | 24 | 8th April 2010 06:00 PM |
