Hi, I've recently upgraded a lovely old bakelite radio with modern amp and two way speaker. Trouble is the lack of bass. I guess there are lots of reasons for this and id like to try and resolve it.
Its a table top radio with a 4" driver and due to the buttons and knobs the cabinet is not sealed. How do i go about finding a solution? Packing, sealing it up, different driver, ports etc all seem like options. I realise this is a very open question but your help is much appreciated. Thanks |
#2 |
The glib answer would be to add a sub.
What you have in an OB. Open Baffle. You will not get any frequency out lower that the distance from the front to the rear of the driver unless you can design some sort of enclosure inside the box. I'll let the full range experts suggest a driver. Stuffing is only going to buy a Hz or two. |
#3 |
Open backed radios tended to use high Q drivers to compensate for the open baffle off. They have poor efficiency higher up but are better than using a higher efficiency driver that needs bass boost depending on the power from the amplifier available. The amplifiers in most old radios and TV's are not nominally flat, and they are not suited to nominally flat speaker arrangements, they were optimised to work best together, and the best versions also compensated for for treble roll-off at the top end. There is also the possibility it never did do bass and it can't. rgds, sreten. I'd recommend shelving EQ in the new amps feedback loop. Add a series cap and resistor parallel to the lower feedback resistor.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 10th September 2012 at 11:21 PM. |
#4 | |
The cabinet is 6" deep. B3X95U 00F Radio Philips; Eindhoven tubes international!;, b and I have used this driver Visaton - Lautsprecher und Zubehör, Loudspeakers and Accessories fastended to a MDF adaptor ring needed to mount it correctly. |
#5 | |
I have swapped the 2R2 for 56R, to reduce the gain, allowing it to handle line level audio input. What values R and C would you suggest for this modification? Thanks! |
#6 |
I am with Sreten on this one. A little EQ is about all you can do. A LITTLE. You need to be able to measure what it is doing to see where you can add just a tad. Past that, you are asking to do something that just won't work out. Do be careful messing with the feedback to be sure you don't effect the stability.
#7 |
The damping of TDA2003 is too high...try whit a series resistor near 10 ohms...it will improve the low end...
#8 |
Again? Series resisters do not magically produce bass. The make a better load for the amp, but you are now making your 10W amp a 4W amp. Try it, no harm.
#9 | |
"Any fool can know. The point is to understand" - Albert Einstein Last edited by zobsky; 14th September 2012 at 11:25 PM. |
#10 |
I've tried a reasonable car speaker but still could do with more oomph. Can i not add some capacitance to the negative feedback loop to reduce the upper frequency gain? Or... add an RC network to the line input to reduce the upper frequency gain..
The overall gain then be lifted. |
| Lack of bass with LM3886 | maillard | Chip Amps | 40 | 18th February 2013 09:13 PM |
| Bass & Treble controls, or rather lack of. | Archibaldy | Tubes / Valves | 46 | 7th May 2012 12:43 PM |
| Active RIAA lack off BASS | wabun | Analogue Source | 1 | 5th October 2010 07:33 PM |
| Class-D lack of sustained bass Myth | Zero Cool | Class D | 15 | 9th July 2009 05:41 AM |
| lack of bass in a 6h30 design | SunRa | Tubes / Valves | 3 | 31st January 2007 09:54 PM |
