New Jordan driver - preliminary details - Page 21 - diyAudio
Old 28th January 2013, 11:44 AM   #201
Scottmoose's Avatar
I'd call them complementary. Martin's cover a much wider variation of pipe tapers & driver offsets, but not the coupling-chamber type, or different types of stuffing material. They also have slightly different alignments; Martin was aiming to extract a little more LF output. There is also a spreadsheet available for Martin's alignments so you don't need to do the calculations manually. AFAIK, nobody ever extended Augspurger's work sufficiently to create an equivalent spreadsheet, although it could be done. Rick Schultz (sort of) continued Augspurger's work for simple untapered pipes in his Alpha TL article for AudioXpress.
Old 28th January 2013, 04:45 PM   #202
frugal-phile(tm)
planet10's Avatar
Originally Posted by Colin View Post
are the Augspurger alignments still valid or have they been replaced by MJK's work?
Augspurger & MJK are contemperaneous. Both released their work in Fall 1999. Augspurger did no follow u, Martin has been continually refining his. I consider Augspurger as a ref for using MJK.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th January 2013, 05:27 PM   #203
Colin is offline Colin  United Kingdom
OK, thanks to Scott and Dave.
I ask because I'm on a Mac and not inclined to install Windows/Parallel. Plus the higher cut-off of the Augspurger's alignments fit with what I'm trying to do with subs. The new extended alignments in the SB article look interesting but off-topic for here, perhaps.
Old 29th January 2013, 06:02 PM   #204
Colin try Crossover I use it to run WinISD on my iMac though it may not cope with more intensive programs.
Old 29th January 2013, 06:19 PM   #205
chrisb is offline chrisb  Canada
Now that looks very interesting - nice to avoid the countless entreaties for updates if you're using Parallels and an old XP license on your Mac, and the new W7 has a learning curve of its own. I'd rather simply have my computer do what I ask than have it tell me it's out of date every couple of weeks.
Sorry for the hyperbole (or is it? ), but I'm currently going through the process of replacing my 8yr old PC at work with a new W7 machine in a networked environment, and all the joys entailed therein.
on hiatus
Old 29th January 2013, 06:20 PM   #206
Once you go Mac you never go back
Old 29th January 2013, 06:32 PM   #207
preaching to the choir brother
Now only if I could convince the management at work to try Minis / server - the owner has recently converted to MacBooks, but he's hardly ever here, and the "tech" expert is old school - dare I even say, red-neck Alberta cowboy.
karma's gonna get me for that one
on hiatus
Old 29th January 2013, 11:09 PM   #208
doorman is offline doorman  Canada
doorman's Avatar
Karma you may temporarily escape, his diesel 4x4 may be harder to evade!
don
Old 29th January 2013, 11:21 PM   #209
vinylkid58's Avatar
It's impossible to evade them in Langford.
jeff
Old 30th January 2013, 01:14 AM   #210
jeff
tru dat
on hiatus
I really need some details for this driver. Boscoe Subwoofers 1 18th April 2010 05:19 PM
Driver details Twisted85 Multi-Way 7 1st November 2009 06:00 PM
details for videologic digitheatre dts sub driver please m1c Subwoofers 8 5th October 2008 01:24 AM
SMPS driver transformer details needed dhanukak Power Supplies 0 25th September 2007 07:17 AM
Jordan driver sma Full Range 0 12th February 2004 12:07 PM
Copyright 1999-2017 diyAudio
