New Jordan driver - preliminary details
Old 26th January 2013, 11:14 PM   #191
mdikovics is offline mdikovics  United States
Originally Posted by GM View Post
it seems that no matter how many times it gets posted or who posts it, the vast majority of folks 'raised' on stupid high DF amps and T/S specs don't understand that a loudspeaker is just one link in the signal chain, so best overall performance requires designing it as part of a system that includes the room.
GM
Amen!
And thanks...
Old 27th January 2013, 08:50 AM   #192
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
No argument from me.
Old 27th January 2013, 10:32 AM   #193
Scottmoose's Avatar
Mike: the numbers come from the excursion graph you posted, and the graph for the box I did (part of the set I posted several pages ago). They simply list the numerical deflection values for each in mm in 10Hz increments. Everybody else seems to find it clear enough. The point was to demonstrate your apparent claim that a low-tuned vented box reduces exursion in the octave above Fb is (with certain exceptions) erroneous, and also that despite your professed desire to keep displacement down in the 60Hz - 150Hz region, the same Eikona drive unit in the enclosure I did, which you have taken such exception to, has considerably less travel in this zone. It also has less travel at lower frequencies, except in the narrow area (approximately 30Hz - 38Hz) around Fb in the enclosure for the excursion graph you posted. Normally you would be correct: a higher tuned box usually means a greater risk of uncontrolled driver oscillation when it is presented with a signal below Fb. However, it seems that you have failed to consider the high damping levels and relatively unreactive load of the enclosure I posted, resulting in quite linear excursion behaviour, clearly shown in the excursion and impedance plots I posted. That is one of the objectives behind using this alignment in the first place. You don't like it, which is fine, but unfortunately, you don't seem to understand it.
Dave's comment was perfectly solid, but perhaps not made entirely clear. A low tuning frequency does not automatically result in problems higher up. But like anything else it is a compromise. Assuming a quality alignment, these can include increased driver excursion, and thereby reduced LF dynamic range, along with higher distortion levels from both electromechanical and acoustical effects. Of course if a poor alignment is chosen, you can add that to the list too.
As for step-loss, I will make one last attempt to explain it to you.
-Look at the published frequency response for the Eikona drive unit again. Does it look a smooth declining curve to you below 1KHz, as a mathematical IB derivation looks? No. We see that from 800Hz, down to ~250Hz, the response gradually rises relative to the midband. See the attached. I've drawn some lines in to show the average slope; I've even added a second one for a shallower slope if you prefer to view it in that fashion. This is the actual IB curve of the drive unit, presumably taken on an IEC baffle under anechoic conditions. Although not as extensive as the lift engineered into some (not all) of the MA drivers, it is sufficient to be useful.
-The baffle of the box I designed above is of 9in diameter, assuming 3/4in build material. That corresponds with a step-loss F3 of approximately 506Hz. Since the IB response of the Eikona drive unit is steadily rising at this point, and below, down to about 250Hz where it finally rolls away, this goes a reasonable way toward compensating for step-loss, particularly when you consider that below around 300Hz you will begin to get some help from the room under most practical conditions where a 5in wideband drive unit is likely to be used.
-The enclosure alignment I did provides reasonably broadband gain from Fb to around 150Hz. With average room-gain increasing in the < 300Hz region, in many situations you will thus obtain a reasonably balanced response without needing to resort to Eq, be it in the form of a shelving filter or other forms. There may be a dip in the response between ~150Hz and 250Hz, but in most cases the room will provide some help here, and since it dominates the response of a point-source speaker in this region, you are unlikely to get anything particularly flat anyway. Combined with our falling hearing acuity in the LF, you end up with a fairly practical combination. This is a rather well known and understood alignment quite commonly employed in pro-audio and elsewhere. So please stop claiming I need to 'do a little homework.'
Old 28th January 2013, 05:42 AM   #194
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
I have taken a hatchet to what remained of the posts (some had already been deleted) from the last 18 hours.
Debate Ideas. Do not attack people. If you do want to attack an idea make sure you have some credible reasoning to back you up.
BUT try to keep in mind that different people have different design goals and priorities. Building speakers is all about tradeoffs. Which tradeoffs you choose to live with is all part of the art.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 28th January 2013, 10:19 AM   #195
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
I'd imagine the Eikonas will be popular in FR ML-TQWT designs;
anyone made the plunge and ordered a pair ?
Old 28th January 2013, 10:56 AM   #196
Colin is offline Colin  United Kingdom
I've ordered but there's a waiting list.
Ref Smallangryboy's design - it reminds me of a folded version of the off-set TL alignment, as described in George Augspurger's AES paper. I haven't tried that one but had a go at the chamber decoupled TL (aka Daline) that he mentions. It worked quite well with the JX92 and gave a compact, floor-standing enclosure, at the expense of bass extension. It was tuned to 70 or 80Hz, if I remember right.
Old 28th January 2013, 11:08 AM   #197
Scottmoose's Avatar
Right. Augspurger's alignments were essentially for creating something akin to a 'pure' TL, so F3 is usually higher than an equivalent reflex alignment, with the usual tradeoffs for & against. IIRC, they give a maximum 1dB dip at the 3rd harmonic & no more than 0.5dB variation above that.
BTW, there are some typographical errors in the tables contained in the AES paper, or at least the versions that I've seen that mess up the volume alignment. These were fixed for the somewhat expanded set of articles later published in Speaker Builder.
Old 28th January 2013, 11:10 AM   #198
Oh good. There's nothing quite like building on the back of a typo.
I'll have to see if I can track down the Speaker Builder articles.
Old 28th January 2013, 11:14 AM   #199
Scottmoose's Avatar
You might not have done; it could have been fixed in other versions of the AES paper too. The SB articles (you only need the 3rd one) are the ones to use if in doubt though.
Either way, an Augspurger aligned TL is never going to be a bass monster because that wasn't what he was trying to do, but the optimum volume is of course preferable.
Old 28th January 2013, 11:25 AM   #200
Thanks, I've tracked them down.
If happy to leave bass monsterism to subs, are the Augspurger alignments still valid or have they been replaced by MJK's work?
New Jordan driver - preliminary detailsHide this!Advertise here!
I really need some details for this driver. Boscoe Subwoofers 1 18th April 2010 05:19 PM
Driver details Twisted85 Multi-Way 7 1st November 2009 06:00 PM
details for videologic digitheatre dts sub driver please m1c Subwoofers 8 5th October 2008 01:24 AM
SMPS driver transformer details needed dhanukak Power Supplies 0 25th September 2007 07:17 AM
Jordan driver sma Full Range 0 12th February 2004 12:07 PM
Copyright ©1999-2017 diyAudio
