New Jordan driver - preliminary details
Old 9th September 2012, 07:59 PM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by sreten View Post
I don't know the politics, but I'm expecting it to be a very expensive driver for what is.
I am afraid that may be true. And it has a long way to go to catch up with A7.3/A10.2
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th September 2012, 08:55 PM   #12
R-Carpenter is offline R-Carpenter  United States
R-Carpenter's Avatar
dave
Dave, the new Jordan driver isn't out yet but you are already dismissing it due to predicted insufficient performance and higher price. Do I sense a little bias here again?
I have compared 10.2 to a XJ92 non shielded version and they are different animals. However, harmonic content, power handling of 92 were superior to A10. A10.2 is $110 while non shielded xj-92 was around $150. Not exactly a world of difference. Not to mention crumbling cones of A10 under stress.
Why don't we wait for the new Jordans to come out and then see what they are actually capable of. Ted has been around for a while and I think he's got a few tricks up his sleeve.
http://www.diy-ny.com/
Old 9th September 2012, 09:05 PM   #13
norman bates is offline norman bates  United States
norman bates's Avatar
true, he does have a large head start, but the mark's are always testing, listening, and tweaking also.
Norm
Old 9th September 2012, 09:21 PM   #14
frugal-phile(tm)
planet10's Avatar
I am not dismissing it at all. Competition is good and i would not dismiss Ted's capabilities out of hand. If pricing is similr to what it has been in the past -- as pointed out by Sreten -- then it could be expensive. And that catch up is needed is just a fact, i didn't say Ted + Lowther couldn't do it.
To be truly competitive, strides (over JX92) need to happen, and they need to be priced agressively.
dave
Old 9th September 2012, 11:38 PM   #15
rjbond3rd is offline rjbond3rd
Price per se is irrelevant, as more options are always better, and in reality, these two boutique companies end up making each other and the market stronger. So the competition angle doesn't hold much sway because this is a very small market. Adding a zero or two gets into Feastrex territory, and honestly, some of those drivers are worth the price (and some aren't).
I will buy the Jordans as well as more Alpairs, Fostex, even the Omega DIY driver if that ever comes out. If the Jordans prove to be less destructible, that would also factor into price-performance. It's exciting that there's at least a -chance- of something new and great coming out.
Old 10th September 2012, 12:03 AM   #16
frugal-phile(tm)
planet10's Avatar
Originally Posted by rjbond3rd View Post
... more options are always better, and in reality, these two boutique companies end up making each other and the market stronger.
Indeed. FR vrs multi-way. The more choices the stronger the segment and the more manufacturers can put into R&D.
I'll get a pair of these when i can, just to see for myself where they land.
dave
Old 10th September 2012, 01:56 AM   #17
talaerts is offline talaerts  Belgium
I was also a bit surprised by sreten's immediate dismissal, base don a few numbers (as opposed to listening). Mr. Jordan's knowledge about speaker design is highly regarded, hence I am more neutral/positivily curious about this new driver.
It is true that Markaudio also makes very nice boutique drivers at a price that is not crazy. Unfortunately it is difficult for me to diy currently as I am living in a condo until the end of next year, otherwise I would have ordered their A12P already. Meanwhile I keep reading and thinking of future projects, in fact I want to have audio in all rooms of my house, and it will be a mix of multiway and fullrange drivers ...
Old 10th September 2012, 07:51 AM   #18
zman01 is offline zman01  Bangladesh
Talaerts,
How about ordering a flat-pak from TwinAudio and going to Hong Kong for a day trip to pay Mark a visit and pick up the drivers (and the flat-paks)... should save you the post, and there should be a few good deals for Sg-HK from the budget airlines operators...
You can check out a few other things audio in Hong Kong too.
Old 10th September 2012, 09:08 AM   #19
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Thanks to the original poster for the heads up. Looks like an interesting driver.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 10th September 2012, 09:13 AM   #20
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
You mean a low Qms, high mechanical damping... with numbers like that we have a candidate for current drive
dave
Sorry, brain lock. What do you expect, I was at a Patti Smith concert. It tends to affect your mind.
New Jordan driver - preliminary detailsHide this!Advertise here!
I really need some details for this driver. Boscoe Subwoofers 1 18th April 2010 05:19 PM
Driver details Twisted85 Multi-Way 7 1st November 2009 06:00 PM
details for videologic digitheatre dts sub driver please m1c Subwoofers 8 5th October 2008 01:24 AM
SMPS driver transformer details needed dhanukak Power Supplies 0 25th September 2007 07:17 AM
Jordan driver sma Full Range 0 12th February 2004 12:07 PM
