New Jordan driver - preliminary details
Old 26th January 2013, 01:10 PM   #181
rdf is offline rdf  Canada
rdf's Avatar
Originally Posted by Scottmoose View Post
You were talking about reduced excursion in the octave above tuning (utter twaddle since it is a rather well known fact that this is the region of maximum excursion in most vented box configurations, the one you posted self-evidently being no exception)....
Post 166? It's been a while but isn't the dashed blue line free air excursion? If so excursion would appear to be lower for the vented case, as well as closed box as I recall. The peak above tuning frequency is still substantially lower. What am I missing?
Ears aren't microphones.
Old 26th January 2013, 01:25 PM   #182
Colin is offline Colin  United Kingdom
If you want to maximise dynamic range, that's certainly the way forward. There are limits to what unsupported wideband units, even ones with considerable travel available to them, can do.
Yes, that's what I was getting at - although I can certainly see the attraction of going for bass extension. It's the usual matter of choosing your own particular compromise, although I don't find the satellite/sub approach loses anything, other than floor space.
Old 26th January 2013, 01:31 PM   #183
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
The gentleman was, I believe, claiming an MLTL with an F3 of 30Hz provides reduced driver excursion in the octave above Fb compared to enclosures tuned to a higher frequency. Which is nonsense, since in the vast majority of vented alignments (including the one for which he posted a displacement curve) maximum driver deflection occurs in this region. This octave naturally varies according to Fb. It is ironic though that the MLTL alignment I posted, which Mr. Dikovics has taken such an exception to, provides considerably lower driver deflection in the 60Hz - 100Hz region he originally stated he was concerned about, and indeed at all other frequencies < 150Hz, apart from the narrow region around Fb in the plot he posted in post 166. Of course, being tuned higher, my box doesn't have as much output in the low 30Hz regions, trading this off against a more balanced output higher up, a very flat impedance load, and very linear driver deflection. Here are the two displacement plots together, to ease comparisons:
Old 26th January 2013, 01:32 PM   #184
FWIW, my take on the debate between Mark and Scott is that it is valuable to have different approaches to enclosure design. Pick the designer whose preferences matches your own. The more designs available for a given driver, the better.
Old 26th January 2013, 01:38 PM   #185
Scottmoose's Avatar
Exactly Colin. I have no issues whatsoever with Mark's boxes; they are self-evidently perfectly valid enclosure designs of their type. But they are not the only valid type of MLTL alignment, and my purpose behind providing the one a couple of pages ago was to offer something a little different from the more usual run. For it, I decided to use an alignment I regularly employ, and known to be very effective. This is DIY: as you say, a range of box alignments to suit different preferences is usually nice to have, at least in my experience.
Old 26th January 2013, 04:52 PM   #186
Scottmoose's Avatar
Disregard some of the above. I think we shall leave it that Mike and I have provided different box alignments. With any luck, a mod. might clean the thread up a bit, since it's a distraction from the Eikona, which isn't fair.
Originally Posted by smallangryboy View Post
Scott
I wondered if you would be able to do me a favour? Would you be able to see how both the Jordan EIKONA and the EAD E100HD may model in this cabinet?
Sure. With the Eikona at any rate. A handful of FR plots attached; sans, with light & slightly more extensive damping. The other graphs assume the latter (0.5lbs ft^3 damping throughout). It doesn't go very low & has a bit of harmonic ripple, although in practice I'd expect that to be slightly less than indicated. Note that these are quasi-anechoic plots, that do not consider room-gain, amplifier output impedance, or the driver's actual rather than mathematical response. Carefully positioned, you may be able to get away without any compensation circuits since you've a free space baffle F3 of about 646Hz. The LF of the Eikona is rising somewhat at this point relative to where it's at between ~800Hz - 4KHz (see attached. Every little helps), & when it finally rolls off, the box may provide some balancing gain. Might be a bit of a dip between these points, but we're in the region dominated by the room in any case, where you're never going to get anything flat without masses of measurement & Eq.
If I'm honest, not great, but for what it is (a very small TL), I've seen worse.
Old 26th January 2013, 05:00 PM   #187
smallangryboy is offline smallangryboy  United Kingdom
Sure. With the Eikona at any rate, I've seen worse for what it is (a very small TL). A handful of FR plots attached; sans, with light & slightly more extensive damping. The other graphs assume the latter (0.5lbs ft^3 damping throughout). It doesn't go very low & has a bit of harmonic ripple, although in practice I'd expect that to be slightly less than indicated.
Thanks Scott, very much appreciated, scratch that design then...
Old 26th January 2013, 08:54 PM   #188
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
The other graphs
Of note should be the impedance curve. Guys, time to break out your current amplifiers.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th January 2013, 10:22 PM   #189
Scottmoose's Avatar
Yeah, it's almost as flat as the MLTL I did, so those using amplifiers with a high output impedance should be fairly happy. They're about as unreactive as it gets.
Old 26th January 2013, 11:09 PM   #190
GM is offline GM  United States
GM's Avatar
it seems that no matter how many times it gets posted or who posts it, the vast majority of folks 'raised' on stupid high DF amps and T/S specs don't understand that a loudspeaker is just one link in the signal chain, so best overall performance requires designing it as part of a system that includes the room.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
New Jordan driver - preliminary detailsHide this!Advertise here!
I really need some details for this driver. Boscoe Subwoofers 1 18th April 2010 06:19 PM
Driver details Twisted85 Multi-Way 7 1st November 2009 07:00 PM
details for videologic digitheatre dts sub driver please m1c Subwoofers 8 5th October 2008 02:24 AM
SMPS driver transformer details needed dhanukak Power Supplies 0 25th September 2007 08:17 AM
Jordan driver sma Full Range 0 12th February 2004 01:07 PM
