New Jordan driver - preliminary details
Old 28th December 2012, 12:18 AM   #121
phivates is offline phivates  United States
Default CNC
Most DIYer's do NOT have access to CNC machines, so I must assume that your post gets this point. My point would be that "pin cushion" frames have been around for decades so as woodworkers we would have accepted the challenge of transferring this pattern to the baffle. Not rocket science! Not easy! See what I mean?
Old 28th December 2012, 12:27 AM   #122
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
might be a good idea if Jordan could supply a Solidworks cad file for download, then DIYers cd then just get everything done cheaply on any 3 axis
Old 28th December 2012, 01:02 AM   #123
xrk971 is online now xrk971  United States
xrk971's Avatar
The old fashioned way of inscribing the pattern with a sharp knife and the hand chiseling with a sharp wood carvers chisel is actually not that time consuming. By the time you program your cnc, clamp and fix the workpiece, calibrate the xyz toolbit, etc. You could be done using a chisel. Really, we should stop complaining about a non-round frame. Cnc is for multiple unit production, making two relief cuts is no big deal.
Old 28th December 2012, 06:01 AM   #124
chrisb is offline chrisb
as phivates notes above, not all DIYers have access to this type of CNC
CNC = Carefully Nudged Chisel
yes, that's true, but once you have those programs saved and if you like the driver enough to use dozens of times, a pair of baffles can be machined in less time that it takes to resharpen your chisel
kinda burnt out - taking a break
Old 28th December 2012, 06:06 AM   #125
xrk971's Avatar
Good one!
Old 28th December 2012, 10:59 AM   #126
yeah understood; but useful for those with access to the internet and can locate a nearby workshop with a 3 axis
Old 14th January 2013, 02:51 PM   #127
smallangryboy is offline smallangryboy  United Kingdom
Anyone had any updates from Ted or Denise regarding the release of the Eikona? Was slated for January 3rd, but I've had nothing from them, nor is there any update on the website.
Old 14th January 2013, 03:39 PM   #128
rdf is offline rdf  Canada
rdf's Avatar
...due to one pair being damaged, a second pair from the group buy of several years ago...
I have a pair from that group buy, as well as an earlier set purchased from CSS when they were still the Canadian vendor. The latter sound much better. Having gone through highly praised TBs and 103 clones, slagging the Jordan is a difficult concept to parse.
Ears aren't microphones.
Old 14th January 2013, 03:44 PM   #129
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
What 'slagging' are we referring to here?
Old 14th January 2013, 08:18 PM   #130
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
THose would be VIFA made, i'm pretty sure all the 3 pair we have had thru hear were Chinese made (none of which we were enamoured of)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
New Jordan driver - preliminary detailsHide this!Advertise here!
I really need some details for this driver. Boscoe Subwoofers 1 18th April 2010 05:19 PM
Driver details Twisted85 Multi-Way 7 1st November 2009 06:00 PM
details for videologic digitheatre dts sub driver please m1c Subwoofers 8 5th October 2008 01:24 AM
SMPS driver transformer details needed dhanukak Power Supplies 0 25th September 2007 07:17 AM
Jordan driver sma Full Range 0 12th February 2004 12:07 PM
Copyright ©1999-2017 diyAudio
